Computers & Internet Logo
Anonymous Posted on Feb 11, 2010
How do i tell the diff between 64 bit and 32 bit windows xp
Anonymous
Level 1:
  • Contributor 37 Answers
  • Posted on Feb 11, 2010
Anonymous
Contributor
Level 1:
Answers
37
Questions
Helped
15032
Points
59
Open your main HDD(most likely local disk C:) and look for "program files x86" if you see this you got the 64bit version.
or right click "computer" in the start menu go to property's on the main page in vista and 7 look under system at system type it will say 32bit or 64bit
MiB8888
Level 3:
  • Master 457 Answers
MiB8888
Master
Level 3:
Answers
457
Questions
Helped
274180
Points
1430
Method 1: View System Properties in Control Panel loadTOCNode(4, 'moreinformation');
  1. Click Start, and then click Run.
  2. Type sysdm.cpl, and then click OK.
  3. Click the General tab. The operating system is displayed as follows:
    • For a 64-bit version operating system: Windows XP Professional x64 Edition Version < Year> appears under System.
    • For a 32-bit version operating system: Windows XP Professional Version <Year> appears under System.
    Note <Year> is a placeholder for a year.
Method 2: View System Information window loadTOCNode(4, 'moreinformation');
  2. Type winmsd.exe, and then click OK.
  3. When System Summary is selected in the navigation pane, locate Processor under Item in the details pane. Note the value.
    • If the value that corresponds to Processor starts with x86, the computer is running a 32-bit version of Windows.
    • If the value that corresponds to Processor starts with ia64 or AMD64, the computer is running a 64-bit version of Windows.
Roland Hall
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 120 Answers
  • Posted on Mar 17, 2013
Roland Hall
Expert
Level 2:
New Friend:
Cheetah:
Answers
120
Questions
0
Helped
18189
Points
165
At a command prompt you can type this in:
wmic os get osarchitecture
What should i download to get 32bit operating system software
What is the difference between 32-bit and 64-bit versions of Windows?
The terms 32-bit and 64-bit refer to the way a computer's processor (also called a CPU), handles information.
The 64-bit version of Windows handles large amounts of random access memory (RAM) more effectively than a 32-bit system. How can I tell if my computer is running a 32-bit or a 64-bit version of Windows?
To find out if your computer is running a 32-bit or 64-bit version of Windows in Windows 7 or Windows Vista, do the following:
1. Open System by clicking the Start button , right-clicking Computer, and then clicking Properties.
2. Under System, you can view the system type.
If your computer is running Windows XP, do the following:
1. Click Start.
2. Right-click My Computer, and then click Properties.
If you don't see "x64 Edition" listed, then you're running the 32-bit version of Windows XP.
If "x64 Edition" is listed under System, you're running the 64-bit version of Windows XP.
Download it here:
https://www.microsoft.com/en-in/software-download/windows8
Vista install
Download the XP driver and it will work for Vista - just make sure you pick the correct XP driver for yr operating system - either 32 bit or 64 bit. Makes a huge diffs if you choose the wrong one. If u not sure wot Vista bit system you have, go to System (in control panel) and look at the System properties, you will see either 32 bit or 64 bit.
3helpful
Instant dvd recorder software 'not responding'
Hello Joshua,
Instant DVD Recorder 2.6.1 UPDATER
  • Please install the Instant DVD Recorder 2.6.1 UPDATER if you are using the Dazzle DVD Video Recorder, Dazzle Video Creator or Dazzle Video Creator Platinum with a previous version of Instant DVD Recorder. This updater also includes the hardware drivers.
  • If you are using a Dazzle product already that includes Instant DVD Recorder version 2.6.1, then you do not need to install this update.
New with this version:
  • added support for Windows Vista 64 bit and Windows 7 (32 & 64 bit)(
  • Includes Windows Vista and Windows 7 drivers (for both 32 and 64 bit) for the DVC 100, 101, 103, 107 hardware NOTE: DVC130 and DVC170 don't have 64 bit drivers and can only be used with Windows XP and Windows Vista 32)
  • 16x9 detection
  • PCM Audio (already included with Instant DVD Recorder ver. 2.5)
Supported Hardware:
  • Dazzle Video Recorder ( DVC90) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator ( DVC130) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator Platinum ( DVC170) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator ( DVC100 and DVC101) - Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • Dazzle Video Creator ( DVC103) - Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • Dazzle Video Creator Platinum ( DVC107) Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • and other compatible hardware
Installation Instruction:
  • To be able to install this version, you must own an Instant DVD Recorder Version 2.x full version
  • To install this Instant DVD Recorder version not as an update but as a full version you need to enter your Instant DVD Recorder Version 2.x serial number during the installation process. The serial number was included in your Dazzle product.
  • With Windows Vista 64 bit or Windows 7 64 bit, you need to install Instant DVD recorder 2.6.1 as a full version.
  • If you own an Instant DVD Recorder Version 1.x full version, to only install Instant DVD Recorder 2.6.1 full version.
  • If you use this Instant DVD Recorder Updater to update the Instant DVD Recorder included with Studio Version 12, 11 or 10, please make sure that Instant DVD Recorder is already installed on you system. Please note that the version of Instant DVD Recorder included with Studio Version 12, 11 or 10 can't be installed under Windows Vista 64.
For Windows XP
http://apps.pinnaclesys.com/cdb/register/enter.aspx?checkRegistration=1&langue_id=7&supportFileID=35261&productid=2250
For Windows Vista 32 Bit
For Windows Vista 64 Bit
For Windows 7
2helpful
My webcam microsoft vx-500 is not working..what will i do to use this webcam ??
You can download the drivers for the webcam from the links mentioned below
Windows XP (32 Bit) LifeCam 3.5 32-bit for Windows XP SP2 or higher (excluding 64-bit)
Windows XP (64 Bit)
LifeCam 2.04 for Windows XP 64-bit
Windows Vista (32 & 64 Bit) LifeCam 3.5 32-bit and 64-bit for Windows Vista
Windows 7 (32 & 64 Bit) LifeCam 3.5 32-bit and 64-bit for Windows 7
Simply download the driver and run the setup it will install your camera, if it does not detect the camera , disconnect the camera and plug in again and it will load the drivers
If you require more assistance regarding this, feel free to contact
regards, BA
2answers
LJ 3050 printer is printing very slow.
TRY HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Hi, i have an HP printer D5160 and the desplay shows the err 03 31 if f4 dd6 and i can't print anything Thank you Aris T.
1helpful
My D7160 cuts the bottom part off of every photo. How do I fix this?
2answers
I installed 4 Gig of RAM memory but only 3.25 shows up.\r\nis there a test I can run to see if the memory cards are working correctly? Thanks. Paul
It sounds like you are running a 32 bit operating system XP, Vista, or Windows 7 (32).
The 32 bit Operating Systems are only able to see and use about 3Gb of RAM. To use a greater amount you will need a 64 bit OS (either Windows XP/64 or Windows 7/64) or one of the open source 64 bit operating systems.
2helpful
2answers
Do i have xp 34 or 64?
Go to the Start Menu and right click on "My Computer" and select "Properties". Your system information is displayed there. If you are running on a 64 or 32 bit system then it will tell you.
Grand Canyon Tech
Grand Canyon Tech
