20 Most Recent Pinnacle Dazzle DVD Recorder Questions & Answers
2answers
No Picture
You need a 'Y' splitter for the video to split between the TV and the Dazzle box.
1/19/2022 1:40:05 AM • Pinnacle Dazzle... • Answered on Jan 19, 2022
2answers
Audio
use windows taskmaster, select process, find dazzle, right click, select priority, real time.
1/11/2022 1:46:28 AM • Pinnacle Dazzle... • Answered on Jan 11, 2022
2answers
There is a small black outline going around my whole video screen.
I had the same problem but I had and still get a red line at the bottom of the screen. Best thing to do it crop it out or just add Pictue in Picture Video effect then set it to full screen then set the width and height so it can crop out it self...hope this helps
11/22/2021 3:21:22 AM • Pinnacle Dazzle... • Answered on Nov 22, 2021
2answers
I have hooked up all
Greets - You are mixing cables up. You need to connect the Dazzle yellow, red, white cables to the yellow, red white cables on the TV. You can't plug standard video/audio cables into the component (red, blue, green) connectors on the TV.
take a look at this diagram, just pretend the devices on the left are all connectors on your TV.
http://www.pinnaclesys.com/presskits/Dazzle/DazzleDVD_Recorder_ReviewersGuide_May06.pdf
Good Luck, Mikeywaf
5/18/2020 9:36:50 AM • Pinnacle Dazzle... • Answered on May 18, 2020
2answers
If i get a dazzle dvd recorder, will it work on
Hi and welcome to Fixyah,
Yes it will work with Windows 7, The only problem that you encounter is if the driver of your device is not detected. Remember that the disc of Instant DVD recorder work with 32 bit only and not the 64 bit.
But no worry there is available driver for 64 bit if your Windows 7 is a 64bit.
2/29/2020 10:41:36 AM • Pinnacle Dazzle... • Answered on Feb 29, 2020
I have dazzle DVC 170
one of the drivers is not compatible or unstable with you system. make sure you have the relevant firmware on your system, update the drivers from the driver menu that is in device manager win 10 its right click on windows logo (start) bottom left and click on the driver and update before using it if no update is available you could try the properties of the software. right click on the icon for the software and menu will pop up go to properties click on that and then go to menu compatibility and click to run on win xp mode or another mode. then press ok.
10/26/2018 2:28:26 AM • Pinnacle Dazzle... • Answered on Oct 26, 2018
I forgot my dazzle dvd recorder hd serial number
S/N: 107X00624W69 S/N: 428X00156T72 S/N: 321P00208H73 try this maybe it could help you
9/18/2018 3:04:57 PM • Pinnacle Dazzle... • Answered on Sep 18, 2018
0answers
0answers
Losing Audio Halfway Through Recording
The audio failure sounds more like a VHS player failure than a DVD software/recorder failure. Both audio and video are transferred at the same time to the DVD, and as long as the DVD recorder is working, that's really all there is. I would check the VHS player and confirm that the sound actually works all the way through.
3/2/2017 12:24:19 AM • Pinnacle Dazzle... • Answered on Mar 02, 2017
2answers
Burn error Instant Dvd Recorder windows 7 Dazzle dvc 100
Set the compatibility back to windows 7 and then uninstall the program and all of it's drivers, then reinstall it and see if it works then.
5/1/2016 5:35:10 PM • Pinnacle Dazzle... • Answered on May 01, 2016
Pinnacle Dazzle DVD Recorder Logo
457 questions posted
Top Pinnacle Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Pinnacle Computers & Internet
Most Popular Question
hookup
  • Computers & Internet
