I assume you mean it sounds like a jet plane when it spins, if so, I suspect a bad tub bearing. Depending on age of the machine, probably too expensive to repair.
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
The bearing in the outer tub assembly is going out and you will need to replace it. Here is the part if you want to order it but you might want to look into buying another machine.
I would suspect that the main drum bearings have failed.
From the front of the washer, spin the drum by hand, and if it feels rough or is noisy, then the bearings have failed.
There should be little or no noise when you spin the drum.
most likely transmission bearings are worn out (sounds like a jet plane taking off) unfortunately this requires replacing the transmission which is a costly job.
Sounds like the drum bearings have gone and the belts come off.
Im afraid this is an expensive repair and not a diy job.
Sorry to be the bearer of bad news.
thankyou for using Fixya.
Hello julierealtor how old is the washer? Try turning the inner drum by hand and see if it is noisey or moves up and down. If so then it is either your rear support of the inner drum that has failed or the rear bearings. If it seems fine, maybe you have something in the drain pump (which runs prior to and during the spin) that is causing the noise. If it is noisy during the drain, then you may either need to clean out the pump or replace it. Hope this helps.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
