Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
Posted on Jan 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove write protection from a 4GB pqi USB flash drive?
laikexpert
Level 3:
President:
  • Master 281 Answers
  • Posted on Feb 02, 2010
laikexpert
Master
Level 3:
President:
Answers
281
Questions
0
Helped
272341
Points
1232
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
kieran tuson
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 26, 2012
kieran tuson
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5681
Points
How to ******* un file a protectid file on a kingstone usb 4 g
Usb drive u167 not recogized
Follow the below steps:
Go to device manager>Universal Bus Controller>Remove all items.
THEN go to driver>uninstall>click ok>delete devices under the universal bus controller and then reboot the system.
Afterwards connect your Usb drive and check it is showing or not....
1helpful
How can i convert 4GB usb 8GB
you cant
if you want to get the maximun ammount of storage space create a folder or add files to a zip file to compress them
to make a folder right click in the drive select new folder and name it
hope this helps
Read-only files and how to them?
Possibility
Firmware flash drive corrupted (the disk is write protected).
Solution
To repair damage to the firmware, the solution can be found on google seach engines. Example; Fix transcend flash drive, Fix sandisk flash drive, Fix PQI flash drive, etc.
My windows 7 does not see my usb flash memory what can I do when I want to go in my computer I cant see a usb icon to go in
solution 1 .use the lifetime wty. solution 2 .try to enter command prompt and and type in e:\ press enter that is if your only running one drive(c:\) and a dvd\cd(d:\) if not it will be the next letter. hope it helps. personaly i would go with solution 1.
5helpful
PQI U273 4Gb Flash Drive not recognized by Win 7 after first use.
neved alapj?n ?rteni fogod magyarul is, legal?bbis rem?lem.
az a probl?ma, hogy win7 driver egyel?re nem l?tezik az eszk?zh?z (a gy?rt? nem is ?rja, hogy t?mogatn? ezt az op-rendszert. a (nem t?l eleg?ns) megold?s az, hogy haszn?lat ut?n el kell t?vol?tani el?sz?r a pendrive-ot, majd az eg?sz usb-hubot a rendszerb?l (term?szetesen csak szoftveresen: device managerben uninstall), majd ezek ut?n ?jrabootolni. ekkor a win7 ?j hardverk?nt felismeri a hubot ?s az ezek ut?n ehhez csatlakoztatott pqi u273-ast is. persze ism?t csak egyszer...
http://www.pqi.com.tw/faq_1.asp?ID=1579
MY pqi 4gb travelling disk is not working actually it is not getting connect with PC.Any hardware problem?
if you already tried different computers, and checked if the USB port is a known good port, then it might be your USB flash drive thats having problems. Check if your flash drive has lifetime warranty thru PQi's website...you might be able to get that 1 replaced..
Hope it helps..
Top Kingston Computers & Internet Experts
Jean Thiebaux
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
