Moyer Diebel 24 in. 501HT Built-in Dishwasher Logo
Posted on Dec 21, 2009
I have just purchased a used 501HT model and had it installed by a plumber and electrician. It does not seem to work, when I close the door and push the start button. Can you help ? Also, there is a liquid soap hose from the back; is liquid the recommended soap ? Can you use powder in them or not ? Any assistance is appreciated. Alicia
GPEC
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Dec 23, 2009
GPEC
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
3072
Points
29
If your dishwasher has not worked since the intial set-up. It could be any number of problems. I would check and make sure your machine's electrical is hooked up properly. A common mistake during set-up of high temperature machine is an electrician will hook it up to 120V when it should be hooked up to 208V. There is also a service switch located on the inside of the lower service panel, usually marked FILL/ OFF/ ON
This switch will need to be in the ON postion. Also the machine has a extended wash/deelime switch located under the door this will need to be turned off in order for the machine to begin a cycle.
You can use a powdered detergent. A liquid detergent is the best way to go. Liquid is the most economical when set-up and titrated properly, as opposed to manualy filling the machine with powder every load. Powdered detergent often leaves a chemical residue on your warewash.
Regards
Are little plumber electronic descalers any good
Where does the hard water deposit collect?
I can\'t imagine this product actually works.
Many years ago they used to have door-to-door salesmen trying to sell a water softener that worked by installing some sort of magnet on outside of pipe... it was a fraud.
This little plumber product seems same type of scam.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2answers
My jets aren't working. who should i call to fix? a plumber or electrician? can't seem to find a company to service my cielo by whirlpool jacuzzie tub. Txs.
If you can hear the the motor running then call the plumber....if the motor don't run then call the electrician...
Or find someone like me that does it all...:-)
heatman101
When we close the door and put switches on, only the temp light comes on. nothing else happen. Thanks
Could be the switch marked delime is in the on position.. That switch should be in off position. (pushed in at bottom)
My 501HT has stopped draining. It runs through a couple of cycles until the water inside builds up enough to leak out through the door. I have tested the cam switches #3 and #4 and they are opening and...
Hello Dabean
Have you sort out your problem yet if not please email me your problems and I try to sort them out for you my email address [email protected] God Bless have a nice day Dickson
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Installation plans needed
Hi enamelcat,
I'm Harvey the Master Plumber.
Your problem is: You were given a Jensen Air Masseur tub without installation plans. It has a blower to connect - model T02-250-120/60-P2-J1. Is there someplace you can find the plans for this. Your electrician does not know how to connect all the wires. Any suggestions would be appreciated
I can usually wire this up myself, but any electrician worth his salt can figure it out. If you're having trouble finding such a person then you'll have to get in touch with the manufacturer to get an electrical diagram or instructions.
.Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 27, 2008 • Home
1helpful
Whirlpool DU1100XTPS dishwasher leaking from front door panel
Hi karen_kinzer,
The d/w was a recent purchase?
Then my advise to you is don't worry about it! The unit should be under warranty. It's time to make the call. Let the warranty repairman worry about it. If he can't fix it, he has the authority to condemn it and you'll get a new one. Anyway, this is one problem you should not have to worry about.
Thank you,
Sep 13, 2008 • Dishwashers
The Frigidaire Professional Series Dishwasher is leaking dishwasher detergent ( during the wash ) all over my tile floor and staining my grout. It seems like the door will not shut all the way. If I push...
Hi linsley.
Your question is: Is there a way to adjust the closure to close the door more?
First lets back up a little . You say it's leaking dishwasher detergent ( during the wash ). Before you do anything else take a look at the type and/or amount of soap you're useing. Have you recently made a change? I have found that the problem is in this somewhere. If you don't find a solution there then consider a local pro. Unless it's old the problem isn't the gasket and the door closure is factory set. If it's still under warranty then it might be time to make a call.
Thank you,
Top Moyer Diebel Dishwashers Experts
Mike Cairns
Mike Cairns
john h
Are you a Moyer Diebel Dishwasher Expert? Answer questions, earn points and help others
