20 Most Recent
Moyer Diebel 24 in. 301HT-40 Built-in Dishwasher Questions & Answers
We have a 301HT and the door is not staying at the
The manual will show a bushing under the adjusting nut at door frame opening that holds the door from dropping too far. This bushing usually breaks and disintegrates. Bushing is just over 1" long. Check both bushings on each side of door opening of machine.
Moyer Biebel commercial dishwasher
Open the cap on the vaccum breaker. Check the float that is inside and insure that the seal on it is not worn or split anywhere. if it is, replace.
Rinse temp too low, first it comes up to 180
The rinse temp only reaches 180 degrees for a couple of seconds towards the end of the cycle. This will sanitize all warewash and meets most health code regulations. The rinse water temp will drop rapidly as it is incorporated in to the machine and sprayed on the dishes.
Regards
Trying to wire the pump motor. Blue, red, black,
The black and white wires supply power to the motor so that it rotates clockwise when the machine is in it's wash cycle. The blue and red wires are opposite to the black and white. This makes the motor spin counter clockwise. The machine will be in it's drain mode mode when the blue and red wires are live.
Regards
Not using detergent or rinse aid
Do you have a Manual for your machine, if not get one in USA 800.858.4477 in Canada 800 263 5798 we goes from there. God Bless Dickson
Dish washer will not fill with water
First I'll check is there any power to the water inlet valve item #19 if there is power then the water inlet valve is defective, if there is no power check the door magnet Item # 13 I found the magnet itself got loose inside the plastic housing and cause the problem as the door is not closing at all. If you need further help please email me at
[email protected]
God Bless have a nice day. Dickson
Dishwaser won"t darain water out
Occasionally, food and debris from your plates creates a clog at the bottom of the dishwasher either where the water drains out of the machine or within the tubing that carries the waste water out to the plumbing.
You may need to ensure that there are no blockages in the bottom of the dishwasher (remove the food filter and check for gunk), or you may even need to pull the dishwasher out from it's housing (usually is bolted in to the counter by a couple of screws) and check that the out-take hosing is free flowing.
