20 Most Recent
Moyer Diebel 401HT Dishwasher Questions & Answers
How do I fix a door that wont stay closed?
The spring probably broke in the latch, or the door balance springs are slack. You have to pull it out and removed the side panels. The latch literally just holds it in place. You should be able to tell if the springs are holding the weight of the door though. Then split the door to inspect the latch.
New install, used machine, need an old manual.
I'm too late for you but others could be helped. With the power off' make sure the timing cams are set to the beginning of cycle, Then push the cams with a finger untill the fill cam switch just activates. Then put the power on,close and latch door and water should enter the booster. You might have to do this 2 times to get water at correct level inside machine. When the cycle lite goes off check for water inside machine. If water level is too high, then take some water out with a cup.
Overload was tripped on the booster tank?
thats ok, just reset, if it happens again replace. could be that the booster thermostat didnt shut off the one time. Keep an eye on the temperature guage to see that the temperature is not fluctuating too much over 85c
Hi...where do you put the
If the machine still has a detergent pump, then the hose could still be taped to the back of the machine, half way up on the outside. It would have a label on it that says detergent. If the pump is missing then use a commercial grade powder detergent if your health inspector allows it. You would have to put in approx. 1 tablespoonfull each load.
The dishwasher wont get up
possibly the temperature high limit switch needs resetting, by pushing the centre button in with your finger. Make sure power is off first.
