Tip & How-To about Dishwashers
If you are having problems getting the water to drain out of your dishwasher then there are a few things that you need to check out.
First check the drain hose that it has not gotten pinched anywhere. Then check it to see if it may be plugged with dirt and debris. If you have it hooked to a garbage disposal make sure that the hole into the garbage disposal is open.
If all of that checks out, then check the screen inside at the bottom of the dishwasher. Excessive food buildup will block the flow of the water into the pump.
If that is clear then you may need to remove the bottom rack, and the bottom spray arm. This will allow access into the pump. Some dishwashers have a diverter flap that opens to allow the water into the bottom impeller, which is the pump out impeller. Also check that the bottom impeller is in good shape and not deformed. The switch that operates the diverter flap can also go bad. You need to check that it can operate and that is does if power is applied to it.
By checking all of these things you should be able to find your problem. You may have to take the time to eliminate the problems one by one till you get to the cause of your problem.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps...
Daniel
Hi
Hope this helps...
Daniel
