20 Most Recent
Moyer Diebel 48 in. SW400 Dishwasher Questions & Answers
When i pull the main
yes I would say it is the plumbing underneath the drain pan. Probably the u shaped bend in the plumbing is full of straws or bottle caps, and/or glass. Double check the hole under the drain pan screen to make sure it is clear of debris.
We have a model 4001 glass washer that won't stay
Could be that the wash sprays are not going straight up or down to be recycled back into the wash tank. Thereby asking for more water to enter the tank from your supply which might not be hot enough at times. If the wash spray is not straight up or down then a lot of water will just go down the drain.
Heating Element not coming on
Check the heater wiring with a voltmeter. Should be around 208v to 240v. If ok then turn off power and remove one heater wire and check heater with ohmeter for continuity. Replace if no continuity.
Moyer Diebel Model 201LT heating element failures
Without looking at your defective elements it sound like the chemical eat through the element and produce tiny pits tell your Eco Lab Tech to change to another type of chemical they have many kinds to suit your need. Try that . God Bless.
