Pls help.. my printer canon mx328 error 6000? any
Canon mx328 cod error 6000 help me reset cod
Tips to fix Canon Printer Error 6000 on your Canon printer:
As we talked about before canon printer error 6000 is the line feed mistake in your printer. That can resolve by following these means in climbing request.
Strategy 1 Resetting or Restart your Printer canon printer error 6000
To Reset or Restart your printer may help you in settling the Error 6000. Underneath we talk about the means that how to Restart your printer.
Unplug your "Printer" from the "Power Plug," and abandon it for few moments in the "Respite Mode."
Presently, plug the power string on the power fitting and "Switch On" the printer.
Press and "Hold" the power catch for few moments. At that point press the "Stop" catch Twice.
Rehash this system once again.
This time keep in your mind that gradually discharge the "Power" catch.
Press the "Stop" multiple times.
In the event that you are as yet investigating with the issue of blunder 6000, at that point pursue the second technique you will get the best outcome, and you can tackle the issue.
know more at https://www.canonprintersupport247.com/blog/canon-printer-error-6000/
Something is in the way of the carriage in the printer. See this video for guidance:
Common Reasons for Canon Printer Error 6000
There are many factors which can cause Canon printer error code 6000. Sometimes, it has been observed that it affects your window registry system automatic shutting down without prior warning. Here are some very common causes of error 6000:
The line feed automatically gets either scratched or smeared.
Some small particles, debris or foreign objects are stuck in the L.F Drive and causes your printer to show error.
Error codes may also be shown because of any defect in-line feed slit os sensor unit.
For more Info Visit Us:https://www.printererrorsupport.com/blog...
