D-Link Vonage-enabled Wireless Router (VWR-VR) Logo
Posted on Dec 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How should the D-link be setup to work with comcast and vonage? After I set vonage or internet do not work. I tried the comcast modem to d-link and d-link to vonage.
Waston Ven
Level 2:
Sergeant:
  • Expert 205 Answers
  • Posted on Nov 28, 2018
Waston Ven
Expert
Level 2:
Sergeant:
Answers
205
Questions
Helped
68634
Points
840
D-Link router is a high-speed internet service provider, which are available with the clear network, it has very easy setup for installation with secure password Router are connected more than people by phone or computers which is admin share the password to each other. Some time users faced some technical problems and they want to solution by the expert. We have the technical expert who listen to your problems and get the response quickly contact our D-Link Router Support Phone Number by dialing the toll-free +1-833-284-3444 number.
#D-Linkrouterservicenumber
#D-Linkroutersupportnumber
#D-Linkroutertollfreenumber
#D-Linkroutercustomerservicenumber
#D-Linkrouterservicephonenumber
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Dec 01, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557673
Points
31058
If you want to RECEIVE telephone-calls:
COMCAST ADSL/CABLE modem <---> VONAGE <---> wireless-router
Turn each piece off.
Turn on the COMCAST modem, and wait for its lamps to settle-down to a "steady" pattern.
Turn on the VONAGE router, and wait for its lamps to settle-down to a "steady" pattern.
Turn on the D-link router, and wait for its lamps to settle-down to a "steady" pattern.
Restart the computer that is connected to the D-link router,
and you should have Internet access.
1helpful
Setup router with vonage device and dsl modem
For the best call quality, I suggest you connect the Vonage router to the DSL modem, and if necessary, connect the Linksys router behind that. Why are you using a second router, though - you probably just need a switch or hub, if you're trying to connect more machines. Small networks rarely require more than one router. MaverickSolutions.biz may be able to provide additional support if you can give us more details about your installation.
Wireless network gets disconnected
i believe it supposed to be
modem--> vonage -->router
-->phone
1helpful
Internet connection issue. Is it setup or internet service
The problem would be comcast. Your connections are setup correctly. The modems do not control the internet traffic flow, they are made to produce maximum flow.
If more people use the internet, the less flow it will have.
Check all internet options settings, and make sure EVERTHING is set to automatic
1helpful
2answers
I cant connect internet through hardwire(ethernet) but i can connect to internet by wireless... and it keeps on telling me Unidentified network.
Not really ...
1 thing that should not be in common between your wireless and modem is GATEWAY...
Your default modem gateway will be 192.168.1.1
change your router gateway to 192.168.2.1 or 192.168.3.1
to do this ...
1. click on start menu , type cmd , enter
2. COMMAND PROMPT dialogue box opens .
3. type . IPCONFIG
3. note your Default gateway.
4. open internet explorer
5. type your default gateway in browser address
6. it will prompt you to give user ID and password .
7 Your USER ID and password is ADMIN .
8. your router setup page opens .
9 change your local IP address to 192.168.3.1 .
10. Check mark on BRIDGING MODE .
11. Disable and enable your ethernet .
12 . now try connecting to INTERNET .
It should work . .
Internet connection problems
Sorry but that seems to be a pretty convoluted explanation. Here is how it should go.
Vonage unit connected to phone line(s) and cable modem. Linksys connected to Vonage box. Computers connected to Linksys.
Ethernet has a length limitation of about 300 feet before you need another switch (hub) or a repeater. Does your wire length exceed this?
3helpful
Linksys And Vonage Setup Through Comcast
I will try to make this as clear as possible, but if you have nay questions, please come back here and let me know.
You will need 4 things: 1 Surfboard Modem, Wrt54G, vonage router, computer. Put them next to each other without having plugged in anything ( no ethernet, no power cable!). Make sure that the WRT54G router is back to default settings by pressing the reset button on the back of the router for 10 seconds.
  1. Connect the power cable to the Modem. Power light on?
  2. If yes, connect the coax cable from the wall to the modem. (The one that looks like a TV cable)
  3. Connect the power cable to the router and wait until the power light is on steady.
  4. Connect your modem to the router. Plug an ethernet cable first into the modem and THEN into the WAN port (the label says "Internet") of the router.
  5. Plug an ethernet cable into one of the router LAN ports and connect it to your computer.
  6. Power on the computer.
  7. Open the Control panel and the Network Connections applet.
  8. You should see something called "Local Area Connection".
  9. Double-click on it and click the Properties button.
  10. Double-click on "Internet Protocol (TCP/IP)" and make sure both radio buttons are set to "Obtain...automatically".
  11. Close all Windows by clicking "OK".(The second one takes a moment, because it applies the settings.)
  12. In the open window choose the Support tab and you should see your IP address, your Default Gateway (192.168.1.1) and your DHCP server (192.168.1.1)
  13. Open Internet Explorer and type "192.168.1.1" in the address bar.
  14. If you have reset your router to factory defaults, leave the username blank and type "admin" in the password field.
  15. On the first page (Setup), you should set the Internet Connection Type to "DHCP", unless you get a static IP from comcast (which i doubt).
  16. Go to the Wireless tab and ensure that wireless is enabled.
  17. Go to the "Security Tab - Wireless Security" and ensure that NO security is enabled for now.
  18. Open a new browser window and see if you can open a web page. Use an address that is unlikely to be in cache - try "http;//www.mit.edu" or so.
  19. Close your browser for now and come back here later to setup your wireless security etc.
  20. Now power on your vonage router and wait until the power light comes on steadily.
  21. Connect an ethernet cable from a LAN port of the router to the WAN port of the vonage router. (Plug it into the router first!)
  22. The vonage device should blink and establish a connection (Internet light is steady on). This might take a moment, because the device is downloading the newest firmware as well.
  23. Once the vonage router is on and the lights are steady (you didn't say which vonage device you have, so I can't tell how many lights there are), plug normal telephone ( not a wireless one) into the vonage router and see if you can get a call signal.
  24. If you were successful - sit back for a moment, enjoy the triumph and treat yourself with a nice drink!
There are a couple of things you still have to do, but the main thing is done.
  1. Make sure that you can access the internet from your wireless laptop before you start changing settings.
  2. Get a manual for the router here.
  3. Go back to your router's web page and set up wireless security (don't use WEP - that is not secure enough)
  4. You will have to setup QoS (Quality of Service), in order to prioritize your VOIP traffic, so calls go through clear even when you are surfing/downloading.
  5. You can setup QoS via IP or MAC address. Use your vonage router's MAC address (you'll find that on the bottom sticker), because it creates less overhead.
  6. If you plug in anything else into your vonage router, it might be on a different subnet and might not be able to communicate with your other computers (vonage router often use 192.168.15.x as their IP address)
  7. Once you're up and running and feel familiar with the settings for your router, I would change to a different firmware, because QoS is a crucial point for VOIP and I never was really satisfied with the Linksys firmware. I use tomato, for the simple reason that I was afraid of other more complicated firmware and you can always go back to Linksys, of you don't like it.
So...my fingers are bleeding now, but I hope this helped you out.
If so, please come back and let me know. Others might have a similar question.
If not, just tell me where you got stuck and we will go from there. According to the movie 'Galaxy Quest':
"Never give up, never surrender!"
2answers
Vonage does not work with D-Link router
If you plugged a telephone into your D-link router, unplug it - that can not work!
You have to plug your vonage router (WAN port) into the D-Link (LAN port) and connect your phone to one of the LAN ports of the vonage router.
If you do not need the wireless capabilities of the D-Link, you can simply take that one out and only use your vonage router.
If you need more help, I would need more details form you:
Which vonage adapter are you using?
How is your setup (i.e. modem -> D-link -> vonage & computers)
What connections are you using (wire/wireless)?
You can also find help here.
2answers
Connecting DLink thru Comcast Cable Modem and Vonage box
first you see the in the internt explorer in that tools in that is give internet option in that connection>lan settings> if the proxey server is ther then remove it if not ther then go it. i think you get it.
second think is that in your dlink router reconfigure the router properly and give the isp details correct and one more thing is check the dns value.
Vonage phone servive
usually when u get an error code 003, it means ur internet is out, if u have problems getting online it effects the phone. if u have bad cables or an old modem or like wireless or satelite isp's can cause this issue as well, try power cycling the whole network modem-vonage device. al
Vonage Again
Just use a splitter and connect the phone line direclty to officejet 7310 All-in-One line 1 port.
Then make below changes :
Press Setup on the All-in-One. Navigatet to Advanced Fax setup - Fax speed. Set the Fax speed to Slow. Also set the ECM (Error Correction Mode) to Off.
Thanks
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
