20 Most Recent D-Link Vonage-enabled Wireless Router (VWR-VR) Questions & Answers
2answers
How should the D-link be setup to work with
If you want to RECEIVE telephone-calls:
COMCAST ADSL/CABLE modem <---> VONAGE <---> wireless-router
Turn each piece off.
Turn on the COMCAST modem, and wait for its lamps to settle-down to a "steady" pattern.
Turn on the VONAGE router, and wait for its lamps to settle-down to a "steady" pattern.
Turn on the D-link router, and wait for its lamps to settle-down to a "steady" pattern.
Restart the computer that is connected to the D-link router,
and you should have Internet access.
11/28/2018 8:08:25 AM • D-Link... • Answered on Nov 28, 2018
How to change pin of dlink router permanently?
go to wireless security settings of the router and do it u will be able to change the pin
3/15/2014 10:21:04 AM • D-Link... • Answered on Mar 15, 2014
0answers
Want to set up WEP encryption, but the router doesn't seem to accept it.
You have to use a static IP or PPPoE IP Address in order to enable this WEP function. Use the ASCII settings to enter text. Look at the restrictions noted.
10/24/2012 1:28:43 PM • D-Link... • Answered on Oct 24, 2012
My vmr dlink router cant conect wirelessly
You can easily setup your d-link router....read more
8/29/2012 9:38:08 AM • D-Link... • Answered on Aug 29, 2012
0answers
Pin number on D-Link router
If the default password has been changed then -
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
4/14/2011 2:30:28 AM • D-Link... • Answered on Apr 14, 2011
2answers
I cannot find the correct
If you have a computer plugged into the router by an ethernet cord then in theory you should be able find it in the command prompt. Go to Start > Run and then in the Run window type CMD. In Vista or Windows 7, go to the Start Orb and then type CMD into the Search bar, then Right+click the CMD icon that shows up in the list, then select "Run As Administrator." Ok, now that command prompt is open, type IPCONFIG /ALL and press enter. This will bring up a list of all of your connections. Scroll through them and look for Default Gateway (that is the IP address of your router).
I really hope this helps!
1/20/2011 12:31:07 AM • D-Link... • Answered on Jan 20, 2011
Hi, how to create a password for my network, i;m
This is done by navigating your browser to the router and logging in. I suggest that you go to dlink.com and download the manual. Access is similar to 192.168.0.1 in the ADDRESS BAR, not search...
Here are the highlights of what needs to be set.
Wireless Router
It is usually easiest to run the install wizard, but be sure to be ready to set the items listed below.
Things to set:
Note: Routers are intended to be set by geeks. You have to SAVE EVERY page, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes.
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue.
2. Set a recognizable system ID.
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping to bottom of the router. Physical access is not the security issue.
4. Check that your router is set to broadcast its' presence.
1/14/2011 6:39:47 PM • D-Link... • Answered on Jan 14, 2011
My router stop working every
Log into your router, if you do not know the ip address of your router, open command prompt, type ipconfig, hit enter and you look at the default gateway, that is the ip address of your router. put that into the address bar of IE and sign into your router. Once you are in, check the security tab for timing settings.
1/8/2011 6:12:52 AM • D-Link... • Answered on Jan 08, 2011
My computer (Windows XP installed) has working
change the setting in the router to accept any connection.
you will have to log into the router to do this.
10/12/2010 3:16:19 PM • D-Link... • Answered on Oct 12, 2010
How can I secure my wireless
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
9/28/2010 4:27:09 PM • D-Link... • Answered on Sep 28, 2010
3answers
My Internet keeps dropping and coming back on.
Who is your provider? Vonage? I think id be on the phone to them to get this straightened out.
Not Vonage, call who ever is your cable service provider. And if you cant get them on the phone or via WWW, id be getting to the closest office and speak loudly until I got some satisfaction.
9/27/2010 1:00:08 PM • D-Link... • Answered on Sep 27, 2010
I WANT TO KNOW WHAT
Connect a Lan cable to the computer you want to increase your perfomance.
This may sound like a joke, but even the new Draft-N routers give pretty bad pings when playing online. If this is the case for you and you want to increase performance because you are playing online (People, try being a little more specific and not posting just general question...), then your best bet will be to move the router over to your gaming computer and have the rest of the computer wireless.
9/26/2010 4:07:36 PM • D-Link... • Answered on Sep 26, 2010
Vonage device cannot connect to the internet
Have you tried powering on unit and hitting the hard reset button on the back?
5/19/2010 3:45:47 PM • D-Link... • Answered on May 19, 2010
Vonage router
You simply access your router from any Browser suach as Internet Explorer, Firefox , & so on. You simply type in it address, and password and log on and set it up generally there is a wizard to do so. Go to the web site below and get software and a manual so you can follow that and set your self up. http://www.dlink.com/products/?pid=VWR-VR
2/20/2010 2:27:18 AM • D-Link... • Answered on Feb 20, 2010
Does not save wireless security settings
Encrypting the network blocks any unauthorized computer from accessing the network and using its broadband connection. To enable WEP on the router,
1. Open your default browser and enter the following IP address into the address bar: <http://192.168.1.1>
2. When prompted for a username and password type “admin” on password, unless you have previously changed the password of the router, and hit OK. This will bring you to the Setup page of the router.
3. Depending on the firmware of the router. Click on the WEP Key Settings button. Or you can click the Wireless tab and select Wireless Security. Or you can click the Security Tab and select Wireless.
4. From the WEP/Security Settings window, you may enable 64 or 128 bit WEP then enter your Password on the Passphrase field and click on Generate. Make sure to copy the characters on Key 1-4 on a piece of paper before you hit APPLY. You will be needing this once you enable WEP on the wireless PC’s. Also take note that if you enable 64 or 128 bit on the router, this should be the same WEP level that you will enable on the wireless cards.
To put in the network key in your wireless adapter follow the steps below:
WEP Encryption XP's Wireless Zero Configuration ( Advisable for XP PC's )
1. Go to start>Control Panel>Network Connections>Right click on the Wireless connection then click on Properties>Click on the Wireless Networks Tab
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then uncheck “The Key is provided for me Automatically”
3. Type your WEP Keys on both the Network Key and Confirm Network Key field. (This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.) Then hit OK and then OK again.
4. After hitting OK a pop-up should appear on the lower right hand side saying “Connected”. Try pointing your mouse arrow on the lower double monitor icon.
5. Restart your PC
WEP Encryption using the Linksys WLAN Utility ( 98/Me/2000 )
Make sure that the WLAN utility of the Linksys adapter is already is installed. If not, you may follow follow the procedures below for "Installing the Linksys WLAN Utility"
1. Click on Start then Programs, then click on anything that says something about the Linksys Wireless Adapter. On the menu, select either WLAN Utility or Wireless Configuration Utility
2. On the lower right-hand side of your screen, double click on the Linksys Icon. This will bring up the WLAN Configuration Utility.
3. Click on the Profiles Tab. Make sure that the SSID that is set to default is your routers SSID. Highlight Default then hit Edit.
4. Select Profile Wizard. Continue to click the Next button, until you get to the Security Settings Window.
OR select Expert Mode then Next. Then click on Security Settings
5. Set the same WEP level that you have enabled on the router. ( ex. 64 or 128 )
6. Type your WEP Keys. This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.
7. Hit OK then Next. On Confirm New Settings click Yes. And then click “Activate New Settings Now”
1/5/2010 10:53:00 AM • D-Link... • Answered on Jan 05, 2010
D-Link Vonage-enabled Wireless Router (VWR-VR) Logo
42 questions posted
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • D-Link Computers & Internet
Most Popular Question
want set up wep encryption but router
  • Computers & Internet
