20 Most Recent
Arris SURFboard SB5120 Modem Questions & Answers
I have the motorola sbv5120
led 2 to 9, gee it has 8 LED status lamps and not told you which one flashes nor what all do. sure #2 is on power sure.
the SBV is not a router at all so forgot to tell router
or is just 1 PC plugged into ethernet ports> yes/no? we can not see what you have or connected.
page 2 actual covers all that LED stuff in the manual RTM?
PDF#7
well kinks led is data up or down. any data moving up or down blicks this light so that is good blinking never bad.
not told at all , what PC is this.
nor OS
nor if PC using wifi or wired Etherenet. the later is best for testing
LED #5 ONLINE is what matters here first.
LED #5 must glow or call the IPS to get that working
if LED #5 does glow. use ethernet wired to SB
Led 7 and 8 is telephone VOIP so not important now.
not told wifi or ethenet fails, or both
not told if PC wired ethernet to top rear of SBV works
if at PC you ping 1.1.1.1 this works internet is good but DNS fails
if you ping same and it fails internet is dead but led #5 MUST GLOW.
The pc also shows connected in the task bard for SURE using ethernet
if all that passes, we then fix bad love/hate WIFI
ask how.
Hi
I have the Motorola SBV
The SBV5120 is simply a device that converts your cable internet signal to a RJ45 computer output that connects to your single PC
It also has two RJ11 phone jacks if you use the modem as your home phone as well. It has no wireless function,
For you to have a wireless connection, you will need to purchase a Wifi Router. These can easily be got at any local computer store or a big box retailer like Best Buy, Staples, Computer City etc,
Most come as a 4 or 8 port wifi router, your choice will be the number of wired connections. In your case it looks like one.
Once you have your router, connect the Modem RJ45 to the WAN input on the router and your PC to one of the LAN ports on the router. In its default state, it should connect you to the internet as normal.
The router will have setup instructions which you can use after you connect the modem and PC.
WPS
Contact Arris http://www.arrisi.com
I can't conect
i try to connect with my motorola cable modem, but is asking for type user name from and password from isp. i am using dstv decoder
Gateway defualt code
if u are asking about the admin pw you can try the following
Default username: admin
password: blank or admin or password
I can't get ports open
call
1-877-466-8646 this is motorola's tech support line. Thier agents are very very good and will either fix your issue or tell you exacxtly where to go to get it fixed. But if they need to walk you through the set up process t does cost 30 dollars, but they can tell you how to get the set up info for free if you dont wanna pay
