Computers & Internet Logo
Posted on Nov 12, 2009
The wifi of my HP Pavilion dv6000 not working properly
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 22, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
861
Points
Don't have Audio device, ithernet controler, network controller, video controller, modem device HP Pavilion dv6000..pls. give the a driver download i need it..
Hp 650 blank white screen
You may want to check using an external monitor.
The DV6000 series unit have problems with Video GPUs processors. If you have experienced any other kind of issues like the WiFi not working ect. you may have a bad GPU.
Try re-seating the GPU with heat gun ( View on Utube )
Hope this helps
tip
Something about Replacement For HP Pavilion dv6000 Laptop Battery
Replacement For HP Pavilion dv6000 Laptop Battery - Extended capacity laptop battery for hp pavilion dv6000 series.The
lithium-ion replacement pavilion dv6000 series battery sold on http://www.discount-battery.eu.com/laptop-batteries/hp-
pavilion-dv6000.htm works with your notebook to reduce power consumption, letting you work longer than with other types of hp
pavilion dv6000 series batteries.This replacement battery pack is rechargeable, removable, Lithium Ion battery.The Hi-Quality
battery meets or exceeds original manufacturer specifications for your battery in quality, durability, and performance. Li-
ion batteries do not suffer from the memory effect. They generally last between 300-500 charge/discharge cycles. All
batteries are tested for 100% quality control assurance. This battery includes a one year warranty. We offer a 30 day money
back guarantee and fast shipping on all of our products.
on Apr 01, 2010 • Computers & Internet
tip
How to Disassemble an HP Pavilion DV6000
The HP Pavilion DV6000 is one in a popular line of consumer-oriented laptops produced by HP. Relatively inexpensive, the Pavilion DV6000 is a good all-around value for most users. Taking apart an HP Pavilion DV6000 is not an easy chore and if you plan to use the laptop again, it is important you know what you are doing or you have a large appetite for risk. If the above doesn’t describe you, consider taking the HP in for professional repair or upgrade. Otherwise, follow the steps below to disassemble the HP Pavilion DV6000.
18385245_1.jpg?w=200 1、Prepare a clear workstation. Turn off the laptop and remove all power components including the cord and the battery. (Turn the laptop over and you will find the tab to push and pop out the dv6000 battery.) Also remove any peripheral attachments like card readers and USB devices.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250 2、Turn the HP Pavilion dv6000 upside down and unscrew all the screws you find. Try to keep them separate by size so you can put them back in the same spot when and if you decide to reassemble the laptop.
3、Remove the hard drive and memory modules by pulling up on the rectangular compartments. The memory is located in the central compartment (remove by spreading latches and pulling up), and in most HP models the hard drive is located to one side.
4、Remove the optical CD/DVD drive by pulling on the drive face to the left and out of the laptop. Remove the WiFi card by disconnecting the gold connectors on the antenna and pulling the card from its slot.
5、Turn the hp dv6000 back over and remove the keyboard and power panel/media touch pad. Carefully pry the power panel up with a piece of hard plastic near the power button on the left side. Be careful when pulling not to yank the power connection as you might accidentally rip out a wire. Pull back the keyboard to reveal the connections. Disconnect the connections by carefully pulling on the tabs with your thumb and forefinger. If they are tight, wiggle them back and forth while pulling on them to loosen them.
6、Remove the screws that were underneath the power pack/media touch pad. Carefully pry up the top casing and set it aside.
7、Detach all visible connections to the motherboard by pulling gently on them, wiggling them if they are stuck. Gently pull up from the right side of the motherboard and remove. The HP laptop is now fully disassembled.
on Jan 21, 2010 • Computers & Internet
I have a HP Pavilion dv6000 and the webcam does not work , i also tried everything still i couldn't use my web cam
did you try update correct drivers and reboot system?drivers is here -
http://www.hp.com/united-states/products/dv6000.html
Cant get my hp PAVILION DV6000 built-in webcam to work.
try using a real HP driver yet?
downloaded from whom, most non HP sites are virus pits from H3LL.
know that first.
finding drivers for obsolete systems is super hard work.
Pavilion dv6000 (is that the full partnumber or the useless series number)? post the service tag for 10x better answers.
if at HP.com (where you should have gone first) they demand that first. that is because, there are 50 LT in that series.or more
and guess what they all dont use the same chips nor cameras.
carbon date,,,, 2006 ,2007?
just about 10 years old and support ends at 10 years old
XP is dead now for 3 years why run XP
XP must have SP3 loaded, service pack 3 or USB is no good and vast other things super bad.. (old old history that)
only this matters, see those xx below, all facts here matter.
1,2,3 , all do. to match drivers; to OS. just 1 example here of 1000
9000-ppec2icix4tk32ykqb2dko55-5-0.jpg here is the dead files on this LT
deep dead.
http://h30434.www3.hp.com/t5/Printers-Archive-Read-Only/Windows-7-Upgrade-Guide-for-dv6000-dv9000-models/td-p/179816
if you read the real service manual on any HP laptop made
you learn fast there are vast variances in chips used.
and matching drivers same,
some have 3 -4 wifi chips different. in one model.
like this DV6000-1234, see that 1234, vast models exist.
world wide in fact.
I want help, i need the lan and wifi driver in my laptop hp pavilion dv6000 the model..
Hi! You may click here to download the drivers for your HP Pavilion dv6000z. Thanks for visiting FixYa.com!
I have hp pavilion dv6000 and my sound card
Remove the sound card driver from your computer and then install it back after the computer restart. Check your volume settings and the volume slider on your laptop.
1helpful
2answers
Hp pavilion dv6000 notebook is not starting after putting into hybernate mode , black screen, all leds on the panel glow, but notebook doesnt boot
Thats the first problem of that model.They first dont want to go out of hybernate mode after that the wifi will not work and after that the video of that computer will be dead.I had like 30 HP Pavilion dv6000 and i just hey them nov but i can repair them.!!!
Soud doesn't work
i bet the wire is disconnected behind the speaker panel. take the screws out from under the battery and near your battery. pop the panel off and see if they are disconnected.
http://h10032.www1.hp.com/ctg/Manual/c01035677.pdf
first read on how to take it off properly
if you are having a fan problem, black screen problem or any others.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
