20 Most Recent HP (400745-001) Sound Card Questions & Answers
I have an HP DV6000
hi there. go to this link might help you find out whats gone wrong. HP DV6000 laptop dvd drive isn showing up in my computer Google Search
11/19/2017 8:30:37 PM • HP (400745-001)... • Answered on Nov 19, 2017
My computrer has no audio
Have you checked the sound drivers?Goto device manager (Start->Control Panel->System->Device Manager)Then look under sound, if you see yellow exclamation marks / unknown device, you may need to reinstall sound card driver
11/2/2013 12:24:54 AM • HP (400745-001)... • Answered on Nov 02, 2013
I cant hear a sound
try adjusting your volume settings and if it doesnt work then try updating your sound driver. open device manager, right click on the sound driver and click update driver. make sure u are connected to the internet to download the driver. [email protected] if u still have issues. i hope this will solve it
11/12/2012 4:57:16 PM • HP (400745-001)... • Answered on Nov 12, 2012
No sound from my windows
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it if his does not fix the problem click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps you
9/9/2011 10:19:00 PM • HP (400745-001)... • Answered on Sep 09, 2011
The volume and
Right click my computer then properties then hardware then device manager then see if the sound drivers are installed properly if not installed properly you will see a question mark if disable you will see red X id disable enable the if the driver is marked with yellow question mark then reinstall the driver if the driver is installed and no marks indicated go to the speaker icon in the task bear and open the volume control and see wether mute is enabled if enabled disble them
9/1/2011 3:02:24 PM • HP (400745-001)... • Answered on Sep 01, 2011
My computer keep on saying
Older computers do not have the capacity to display newer versions multimedia little wonder to display a warning message of being incapable or defficient of programs. usually a newer computer that displays a warning message of an indication that the programs may have been deleted or maladjusted when a foreign code multimedia is acqired from another computer. for example, downloading multimedia from apple mac computers to microsoft computers would no play even when the computers where in perfectly functioning order.
Important notes;
1. observe the computer modern fetures, compartibilies, sound producing capacity, audio
7/21/2011 6:33:53 PM • HP (400745-001)... • Answered on Jul 21, 2011
Hp pentium 3 sound card
First right click my computer then click properties then hardware then device manager and expand the sound video and game controller and see if the driver is marked with yellow question mark or marked with red X then you will have to reload the drivers and if you dont see any audio drivers then switch of the computer press del and enter bios and enable the audio device then click the volume control in theoolbar and check wether mute is clicked if clicked remove them and adjust volume slider to high
6/2/2011 6:27:48 AM • HP (400745-001)... • Answered on Jun 02, 2011
No sound
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
6/1/2011 10:01:49 PM • HP (400745-001)... • Answered on Jun 01, 2011
Dear Sir MY LAPTOP OPRATING SYSTEM:ms windows
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer make sure you have an earth ******** before touching any parts inside your computer hope this helps
4/26/2011 3:07:20 PM • HP (400745-001)... • Answered on Apr 26, 2011
No sounds in my laptop for HP G7000 models
You can download the drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the XP orVista Windows version of the drivers you require and install them.
Click onthis link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
4/14/2011 8:01:57 AM • HP (400745-001)... • Answered on Apr 14, 2011
Hello
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps you might have to get a portable usb sound card if you mean dont have a sound card installed
4/13/2011 11:21:04 PM • HP (400745-001)... • Answered on Apr 13, 2011
My computer has a message
You may be able to install the missing driver from these WEB sites.
Driver Detective
http://www.drivershq.com/Driver Guide
http://driverguide.com
4/6/2011 12:32:44 AM • HP (400745-001)... • Answered on Apr 06, 2011
No sound at all for
if you are having problems with your sound if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
3/31/2011 8:13:12 PM • HP (400745-001)... • Answered on Mar 31, 2011
I have no sound, speaker
Go to the HP support site. I've got the link for your laptop
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3548343&lc=en&cc=us&dlc=en&submit.y=9&submit.x=12&lang=en&cc=us
Choose the operating system you use and under Hardware - Audio choose the latest audio driver adn install it.
Incase you feel uncomfortable using that link here is the link to the HP support site home page
http://welcome.hp.com/country/us/en/support.html
Enter your model number in the search box and choose "Download drivers and software (and firmware)" and hit search.
I hope this helps.
3/14/2011 7:24:37 PM • HP (400745-001)... • Answered on Mar 14, 2011
2answers
My computer is very slow
You can run disk defragmenter. also run a virus scan. Also check the amount of ram you have installed. If its less than 1GB (1000MB) i suggest upgrading it.
3/13/2011 3:48:10 AM • HP (400745-001)... • Answered on Mar 13, 2011
My hp laptop sound divise
Try installing the latest audio driver.
them. Click onthis link to download the drivers: -
3/10/2011 8:23:28 AM • HP (400745-001)... • Answered on Mar 10, 2011
Can you help me with
1) First scan your system to determine which driver you need: http://h20270.www2.hp.com/ediags/gmn2/index.aspx?detectProducts=Start+Detection+%BB&lc=en&cc=us
2) Alternative free driver updater software, e.g. http://www.innovative-sol.com/drivermax/index.htm - let it scan and update all your missing drivers.
Official drivers are only for Windows 95 and 98: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&dlc=en&softwareitem=33530 (But it states on another website that it might also work on other versions of Windows - try it!)
3/7/2011 1:56:40 PM • HP (400745-001)... • Answered on Mar 07, 2011
Sound card is not found. can't hear anything form
you might need to reinstall the sound card driver
I would need the model of your computer to tell you what driver you need
here you can type the modem number and you can find the driver http://welcome.hp.com/country/us/en/support.html
if you need for assistance I also recommend talking to HP 800-474-6836
3/3/2011 3:29:08 AM • HP (400745-001)... • Answered on Mar 03, 2011
My hp model dv5-2130 has no sound...
first you will need to see if your sound is even on below is a link for you to check this.
http://www.askdavetaylor.com/why_dont_i_hear_music_from_windows_media_player.html
if you are unable to adjust the volume then there is a possibility that need to download the appropriate sound driver for you laptop.
please vote if this was helpful
3/1/2011 1:33:47 AM • HP (400745-001)... • Answered on Mar 01, 2011
Computers & Internet Logo
86 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
computer keep saying
  • Computers & Internet
