On the back side of your router you will find a small hole like button just try to push in safety pin or paper clip (make it straight) push in till all the lights on the router goes off and turn on again.
This will reset your router settings to factory settings.
Either turn heat control dial up, or there should be a 2-button, one UP & another DOWN. Push UP button.
If a single Heat button, the push the button once, it will start to blink, then push again - if temp goes up, you are going in the right direction to get to your desired temp. If going down, then stop & wait till blinking stops - then push the heat button again, it will blink again, press again and now it should go in opposite direction.
This manual will help
http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
I think these are the directions you need
2.0 Alarm and Chime On/Off
2.1 In Normal Display hold B-Button,and push A-Button once:
Chime will be on.
2.2 push A-Button once again: Alarm will be on
2.3 push A-Button once again: Chime will be off
2.4 push A-Button once again: Alarm will be off
2.5 Release B-Button, the Display changes to Normal Display
immediately.
It sounds like you need to re programme the machine. With the machine plugged into the wall and turned on and the headset turned off this is what you do. Push and hold down the start button, while doing that you need to then push and hold down the power button. Hold them down for about 5 seconds, during which time you may a series of up to 3 beeps. Then release the buttons. Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle. This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Try unplugging the washer to reboot the computer board. Sometime power surges at night can cause undervoltage on the board and make it do funny things. Rebooting by removing power for 10 min will drain the board and start with a fresh program. This is true for microwaves, dishwashers, dryers, etc.....
