20 Most Recent
Nokia 9300 Smartphone Questions & Answers
SMART MOVIE
hey buddy try to download applications which are muchly compatible to your phones symbian version, 9300 is S80 v2.. drop me an email so i can give you the list of mobile sites where you can download lots of mobile applications and software related to your phone.
My Nokia 9300 are having
Welcome to FixYa!
Your phone is clearly having an LCD problem.
The best thing that you can do is to full charge the battery and see if anything changes with the battery fully charged.
If it is still in negative colour even if the battery is fully charged, then you need to tighten the LCD screw and see if anything changes. If not, then the LCD needs to be replaced. You need to service your phone to a repair shop because it needs a special star screw driver to tighten or replace the LCD.
Thank you for using FixYa.
Have a great day.
jas247
I need a nokia 9300
I am from pudukkottai near trichirapall(trichy) TAMILNADU state.I need NOKIA 9300 STRIP TO repair my phone. so kindly tell me how cost it is and how can i get it.
MY E-MAIL ID is
[email protected]
thank you
I am using nokia 9300
First of all, is the main screen on your phone working? If it is, you can change the offline mode from there, all you have to do is to press the power on/off button from there and scroll down from the direction button, then you press the middle button of the navigation button, that selects option for you.
But if you cannot see anything on the outer and inner screen, then it means you will have to navigate blindly, it is simple, turn off the phone by pressing and holding the power off/on button and turn it back on, then you press the power off/on button once, scroll down once, and select the option, that way your phone will be out of offline mode.
The problem with your phone that is not allowing the screen to work is that the flex of the phone is weak and not being able to connect the phones information to the screen. Once it is fixed, that should do the job for you.
Hope this information helped you.
How code format nokia 9300 comunicator
Inorder to format your set,you can use following tips; FOR HIGHER ORDER PHONES(LIKE N,X,E series..): Dial *#7370#
then your phone will ask a securitycode,there you can type your code.then it wil format and restart.
FOR OTHER MULTIMEDIA NOKIA PHONES: Here you can't format yourphone,but you can reset it; For that,go to;SETTINGS-RESTORE FACTORY SETTINGS- AFTER CLICKING IT, your phone will ask a securitycode there you can type your code.then it wil format and restart. "IF YOU THINK MY SOLUTION IS HELP FULL TO YOU,THEN DON'T FORGET TO RATE ME"....THANK'S
Nokia 9300i "stucks" after several
That can be a software bug. Try a general reset of the phone and see if this problem is back. If it is, do a Operating System update with a cable and Nokia Suite software. Your PC must be connected to internet.
