Recently changed TV from Panasonic to Sony. Now DVD will only play in black and white, comes on in colour initially then colour disappears after a few seconds. VHS is fine. Tried new scart but that didn't work.
Figure out if yout tv and your dvd is using the same color system, check also if you installed your rca connector on proper video output of your dvd dont interchane yuv to video out connectors ,check also your dvd's video out setting ,like interlace, pc,yuv, rgb, if you are using video in on your tv you should select s-video or interlace if you are using yuv on your tv you should select yuv on your dvd
