20 Most Recent Panasonic PT-47WX53 47" Rear Projection HDTV Questions & Answers
indicates a sound board problem
take it in for a proper diagnosis and quote
Panasonic... | Answered on Dec 07, 2017
R517 is the auto brightness sense resistor, usually 10K. It fails when the LOPTX fails or the tube flashes over.
Panasonic... | Answered on Jun 11, 2017
your best repair is to find another one just like it and swap screens
Panasonic... | Answered on Apr 03, 2017
i have found the easiest way to get the codes to the clo35a model universal remote for phillips... go to the phillips website... here is the link that sends you directly to where you can get the codes. :)
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SRU3007/27&scy=US&slg=en#
Panasonic... | Answered on Jul 01, 2016
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Panasonic... | Answered on Aug 13, 2015
The message about the AC adaptor is precautionary. Uploading a video can take quite a while. It would be disastrous to have the battery run out of juice before the operation is finished because the file would be ruined and you'd have to do it over again.
Panasonic... | Answered on Jan 07, 2015
select the menu button then go to aspect ratio settings. choose wide or 4:3 option aspect ratio.
Panasonic... | Answered on Jan 04, 2015
You might start by cleaning the lenses & mirror(this may use a Mylar sheet rather than mirror,don't try to clean the mylar) then install a new lamp
part#: TY-LA1001 $70.00 http://www.tvpartsguy.com/servlet/the-11855/TV-Lamp-TY-dsh-LA1001-for/Detail
or $49.00 to $80.00 http://www.shopjimmy.com/catalogsearch/result/?q=ty-la1001
If that doesn't cure it you most likely need a new light engine/optic block which would make the repairs cost prohibitive even if you can locate the light engine.
Panasonic... | Answered on Jun 05, 2014
first try cleaning all lenses & mirrors. Considering the age of unit you may need to replace cooling fluid in front of each CRT. I highly recommend a professional to do this if you consider it economically feasible. Possibly 1 or more CRT weak.
Panasonic... | Answered on May 15, 2014
This is a trouble code. Check their website to see if it is a bad bulb, overtemp indication, or a power supply issue.
Panasonic... | Answered on Mar 27, 2014
We recommend you remove the "Digital In" cable connection from the rear of the TV and turn it back on. If the problem persists, we recommend having the TV evaluated by an authorized service center using the below link.
www.panasonic.com/repair
If the TV turns on then we recommend having the Toshiba Home Theater evaluated. Welcome to Panasonic Online Repair
Panasonic... | Answered on Mar 26, 2014
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
Popular Tags
515 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
remove yellow color in center tv screen
  • Televison & Video
