20 Most Recent
Sony MHC-RV777D 220 Volt Hi-Fi Music System Shelf System Questions & Answers
DVD tray not coming out fully and dvd disc tray not rotating
it sounds like the "Tray" loading belt has stretched, You could try cleaning it, this would prove a point but will need replacing. the belt is small (about 20mm diameter) and is located under the disc tray near to the front, removing/replacing it will require the hifi to be dismantled.
No Audio on MHC-RV777D
its a commom fault in all the Hi fi system.its a dry fault put soldering in all components. the problem may be solved.
My sony mhc-rv777d is not working when i on my
MHC-RV777D shuts off itself because of protection mode that is activated to avoid further damage due to defective amplifier output IC in unit.
You need to check/ replace output amplifier IC to solve this issue, if you are not familiar with electronics stuff repair then local repair shop will do this job for you.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
