HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
Posted on Sep 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP Officejet 6500 No scan Options
HP Officejet 6500 XP "No scan Options". "Populate destination list" instruction in "Help" fails, since "Scan to... Setup" does not bring up any menu or "Destination List". Uninstall/Reinstall doesn't change that.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 19, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9220
Points
18
I am trying to scan, but when I press the scan button it states "No scan options. Refer to device doc to troubleshoot". However, I can't find my device doc. I am assuming there is an easy fix?
Anonymous
Level 1:
New Friend:
  • Posted on Mar 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9220
Points
9
I can't use the button either... I have to go to paint program on my computer and chose the option from Scanner or camera... then it scans for me...
Anonymous
Level 2:
Guru:
  • Expert 126 Answers
  • Posted on Sep 23, 2009
Anonymous
Expert
Level 2:
Guru:
Answers
126
Questions
0
Helped
45079
Points
553
It's not your HP Software is the problem. It's your system, are there any updates needed to your system and usually lack of support plug-ins capable to bring your HP Printer show normal.
Scanning procedure is hardware capability, without the Printer appearance and the software provided is you cannot use then. Unlink printing options is in Memory Printer. Automatic Print outs. But scanning too many procedure and assistants. Even you said Uninstall/Reinstall doesn't change, right!
All i have to say is put your System back to where it's you think work good. Use System Restore to do it.
honey
Level 3:
Master:
  • HP Master 262 Answers
  • Posted on Jan 30, 2018
honey
HP Master
Level 3:
Master:
Answers
262
Questions
Helped
320358
Points
1535
Call Hp Support (877-330-0887) they will help you to get rid of the problem.
1helpful
Cannot select scan to destination
To get scan options on your unit you need to update the destination list on HP Solution Center. Please perform the steps given below to populate the destination list.
Populate the destination list:
You must populate the destination list in HP Solution Center for the Scan To options on the unit. Follow these steps to populate the destination list.
NOTE: HP Solution Center is the software that came with the product. You must make sure the software is installed on the computer for all the product functions to work correctly. The software is also necessary for completing this procedure. Install HP Solution Center if it is not already installed.
  1. From HP Solution Center, select the appropriate product, and then click Settings.
  2. Click Scan Settings and Preferences.
  3. Click Scan to... Setup.
  4. Click the Destination List tab.
NOTE: It might take several minutes for the list to populate.
  1. Click each program to include on the Scan To list.
  2. Click the Add arrow. The program listing moves from the left side of the screen to the right.
  3. Click OK.
  4. Now Press scan button on your All-in-One and check whether the scan options are updated.
  5. If the scan options are still not updated then turn off and on your All-in-One and verify the results.
Scanning with an Officejet J3680
Click Start , and then click Run .
In the Open text box, type msconfig , and then click OK .
In the System Configuration Utility window, click the Startup tab.
Search the list for HP Digital Imaging Monitor . tick the box.
If HP Digital Imaging Monitor is not on the list,
the driver was not correctly installed and You need to reinstall the software.
Open HP Solution Center with one of the following methods.
On the Windows desktop, double-click the HP Solution Center icon
On the taskbar, click Start , click All Programs , click HP , and then click HP Solution Center .
If more than one HP device is installed, click the tab for the All-in-One product.
Click Settings .
Click Scan Settings and Preferences .
Click Scan to... Setup .
NOTE: Depending on the computer performance, it can take several minutes for the
Front Panel Destination List to populate after you turn on the printer or computer.
If the Front Panel Destination List contains valid scan destinations,
you need to reinstall the software.
If the Front Panel Destination List is empty, continue with this procedure.
Click OK .
Scan a document using the Scan To button on the front panel.
If the scan fails, try to scan using the HP Solution Center Scan button.
If the scan still fails, re-install the software.
Hope this helps
Ric.
"No scan options, refer to devise docs."
Hi
I have provided the troubleshooting doc, please follow this to resolve the issue.
Solution:
Follow these steps in the order presented to resolve the issue.
Step one: Verify that the Digital Imaging Monitor is ready
The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon normally appears in the system tray at the lower-right corner of the computer screen, and the monitor is ready when a check mark appears on the icon after Startup is complete.
If the Digital Imaging Monitor is in the system tray, proceed to Step two.
If the Digital Imaging Monitor does not appear in the system tray, follow these steps.
Windows 98, Me, and XP
1.Click Start , and then click Run .
2.In the Open text box, type msconfig .
3.Click OK .
4.In the System Configuration Utility window, click the Startup tab.
5.Search the list for HP Digital Imaging Monitor .
6.If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. 7.Proceed to step three to uninstall and reinstall the software.
8.Select the HP Digital Imaging Monitor check box.
9.Click Apply , and then click Close .
10.Click Yes to restart.
Windows Vista
1.Click Start .
2.In the Start Search text box, type msconfig and press Enter .
3.On the User Account Control window, click Continue . The System Configuration Utility window displays.
4.Click the Startup tab.
Step two: Populate the destination list
1.The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
2.Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
3.On the Windows desktop, double-click the HP Solution Center icon.
4.On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
5.If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
6.Click Settings .
7.Click Scan Settings and Preferences .
8.Click Scan to... Setup .
9.Click the Destination List tab.
NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
10.If the Front Panel Destination List is empty, continue with this procedure.
11.If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
12.Click each program to include on the Scan To list.
13.Click the Add arrow.
14.Click OK .
15.Scan a document using the Scan To button on the front panel.
16.If the scan fails, try to scan using the HP Solution Center Scan button.
17.If the scan still fails, proceed to Step three to uninstall and reinstall the software.
Step three: Uninstall and reinstall the software
1.Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
2.If the software installer does not automatically start, complete the following steps.
3.Click Start , and then click Run .
4.In the Open text box, type X:\setup , where X is the letter of the CD-ROM drive.
5.Click OK .
6.On the installer screen, click Uninstall . If there is no Uninstall option, the software installation is incomplete.
7.Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
8.If the model supports custom install, install HP Imaging Device Functions to scan from the printer. The recommended install will install this feature automatically. It must be manually selected during a custom install.
9.Follow the onscreen instructions until the printer software is completely installed.
10.After successful installation, scan a document.
Step four: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Thanks
Riz
My new hp officejet pro L7590 printer tells me that "no scan options" are available. I bought this as a all-in-one printer. help, I need to scan
Hi Kate,
This error occurs if HP drive services are not functioning properly, so try my solution
Solution
3.Click OK .
Windows Vista
1.Click Start .
6.Click Settings .
14.Click OK .
5.Click OK .
Thanks
Riz
When I hit scan it says "no scan options"
Hi just follow the below steps and the problem will be resolved.
Solution:
3.Click OK .
Windows Vista
1.Click Start .
6.Click Settings .
14.Click OK .
5.Click OK .
Thanks
Riz
Scanner doesnt work
Step one: Verify that the Digital Imaging Monitor is ready The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon normally appears in the system tray at the lower-right corner of the computer screen, and the monitor is ready when a check mark appears on the icon after Startup is complete. If the Digital Imaging Monitor is in the system tray, proceed to Step two. If the Digital Imaging Monitor does not appear in the system tray, follow these steps. Windows 98, Me, and XP
  1. Click Start , and then click Run .
  2. In the Open text box, type msconfig .
  3. Click OK .
  4. In the System Configuration Utility window, click the Startup tab.
  5. Search the list for HP Digital Imaging Monitor . If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. Proceed to step three to uninstall and reinstall the software.
  6. Select the HP Digital Imaging Monitor check box.
  7. Click Apply , and then click Close .
  8. Click Yes to restart.
Windows Vista
  1. Click Start .
  2. In the Start Search text box, type msconfig and press Enter .
  3. On the User Account Control window, click Continue . The System Configuration Utility window displays.
  4. Click the Startup tab.
Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
  1. Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
    • On the Windows desktop, double-click the HP Solution Center icon.
    • On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
  2. Click Settings .
  3. Click Scan Settings and Preferences .
  4. Click Scan to... Setup .
  5. Click the Destination List tab. NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
  6. If the Front Panel Destination List is empty, continue with this procedure. If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
  7. Click each program to include on the Scan To list.
  8. Click the Add arrow.
  9. Click OK .
  10. Scan a document using the Scan To button on the front panel.
  11. If the scan fails, try to scan using the HP Solution Center Scan button. If the scan still fails, proceed to Step three to uninstall and reinstall the software.
  1. Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
  2. If the software installer does not automatically start, complete the following steps.
    2. In the Open text box, type X:\setup , where X is the letter of the CD-ROM drive.
    3. Click OK .
  3. On the installer screen, click Uninstall . If there is no Uninstall option, the software installation is incomplete.
  4. Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
  5. If the model supports custom install, install HP Imaging Device Functions to scan from the printer. The recommended install will install this feature automatically. It must be manually selected during a custom install.
  6. Follow the onscreen instructions until the printer software is completely installed.
  7. After successful installation, scan a document.
Step four: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
1helpful
I cant scan, but I can print?
hi,
I understand that your mean issue is that "you cant scan", however, for me to assist you better, I just want to know how did you scan? and what did you use? there are actually two ways on how to scan. Also, what is the operating system of your computer?
1. Scanning using the buttom from the printer.
2. Scanning using the SOlution Center installed on your computer.
Meanwhile, ill just post a troubleshooting steps inorder for you to follow.
SOLUTION: SCANNING FROM THE PRINTER BUTTON.
Intro:
Scanning using the printer button without adding the destination list would somehow give you error message "NO SCAN OPTIONS", inorder to resolve that issue,copy and paste this link to the address bar. (note: just go directly to SOLUTION II (Populate Destination List) using that document.)
For windows Vista:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01391654&cc=us&lc=en&dlc=en&product=1153481
For windows XP:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01388134&cc=us&lc=en&dlc=en&product=1153481
Those are the link that normally we followed. It helps a lot, you can jump directly to SOLUTION II (Populate Destination List), make sure that all the options are already added to your control panel printer list.
Please let me know if the document failed to resolve your issue so that i can go ahead and give you another solution.
Thank you so much.
adonscott
HP TECH
1helpful
3answers
Can not scan to computer
hi,
below are the steps that i want you to follow. The "NO SCAN OPTIONS" refer to the absence of options when you try to scan using the printer button your printer. However, if you are going to scan from the SOlution center installed in your computer, it will scan without any problem.
  2. Click Settings .
  9. Click OK .
  11. If the scan fails, try to scan using the HP Solution Center Scan button. If the scan still fails, please let me know.
Thank you so much.
adonscott
1helpful
4answers
Cardridge problem for my 5610v
try with another cartridge, maybe you have a faulty one.
try cleaning the connectors on both printer and ink cartridge.
k24674
Grand Canyon Tech
Grand Canyon Tech
