SC457 Position error for the image transfer belt’s cleaning unit
- Timing & Condition
• When the belt cleaning section touches the image transfer belt, but the belt cleaning sensor signal remains LOW.
• When the belt cleaning section releases from the image transfer belt, but the belt cleaning sensor remains HIGH.
• Dirty Sensor
• Defective sensor
• Defective belt cleaning shift clutch
• Defective drum peripheral component motor
• Defective I/O control board
• Defective main control board
1. Pull out and re-insert the image transfer belt unit.
2. Clean the image transfer belt cleaning H.P. sensor.
3. Replace the sensor. (Input Check: 5-803-012)
4. Replace the belt cleaning shift clutch.(Output Check: SP5-804-036)
5. Replace the drum peripheral component motor.
6. Replace the I/O control board.
7. Replace the main control board. [Signal Check]
• H.P.: CN219-B2 or TP108 on the I/O control board
The above information are taken from the service manual.
Good Luck!!!!!!!!!!!!!
I already have the detailed instructions on what to do...someone gave me step-by step. But I am not sure where the access it to get to the imaging belt.
