Do you mean the bobbin winding shaft? If so, then you simply follow the directions in manual on page 27. With the front of the machine facing you, remove your filled bobbin from the ‘bobbin winding shaft, and press your left thumb up against the shaft just above the bobbin winder seat (place where you put ur empty bobbin) and push it in a left direction until it pops or snaps back to it’s original position.
Hi, Quite often with Brother machines there is no left/center/right needle position control but rather when the machine is set to sew straight the Stitch Width control will determine the needle positon.
While sewing straight try changing the Width(zig zag) control.
It is possible that it will only move from center to right.
Bob
SOURCE: needle will not move; the bobbin shaft is in the
Force the balance wheel backwards, you may have thread stuck round the raceway
SOURCE: Brother CS80 ..... bobbin winder
The rubber ring on the bottom end of the bobbin winder shaft has degraded, gone all sticky and is probably somewhere inside the casing. You need a new rubber ring fitted. If you are not handy take the machine to a repairer. There are more details elsewhere on Fixya about doing this.
SOURCE: Problem with brother SE400
Looks like this girl does not have any issues with Brother se400 machine.
