Garden Logo
Posted on Sep 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I change drive belt on my toro 22187 - Garden
Anonymous
Level 2:
  • Expert 78 Answers
  • Posted on Oct 28, 2009
Anonymous
Expert
Level 2:
Answers
78
Questions
0
Helped
56047
Points
181
This appears to be a BBC Blade Brake Clutch. This is kinda hard to describe. Its best you take it to a dealer.
There are two belts both are drive. Blade drive and ground drive. The are accessed from the bottom of the machine.U must remove the blade ,then the belt covers. From that point its pretty much self-explanitory. Toro provides an online manual for this.
Changed belt on Toro lawn mower and now won't move blades pto works but won't move
what belt did you change? i assume the drive belt. if it is not exactly the right size it wont work. if it is not routed correctly it wont work. it may have slipped off of a pulley.
Aug 23, 2019 • Toro Garden
Toro 20031 How do I remove the bracket holding handle in place (ele start) Need to replace Drive Belt
Disconnect the negative battery cable.
Raise and safely support the vehicle.
Remove the drive belt shield at the right wheel well.
Remove the drive belt.
Remove the drive belt tensioner mounting bolt.
Remove the drive belt tensioner.
https://www.ronmowers.com/brand/toro
Jun 12, 2019 • Toro Garden
I need to see a manual for the toro model 20370. I need to replace the drive belt
Take the old belt off and take it with you to a lawn mower shop or even a farm supply place that sells belts and they should mathch you up with the right belt.
Sep 05, 2014 • Garden
2answers
Drive belt runs off 42 Toro
HI, I have a Cub Cadet 50" cut I had a similar problem and I had to change the spring on the idler pulley it had lost tension and replacing it solved my problem. Not familiar with your mower but if it has the same principles as mine you might want to try that.
How to replace drive belt on toro recycler
First thing you need to do remove spark plug wire.. Then I would go to the website for Toro have the serial number ready there you will see the full picture of the way it is then go from there that's the best way with out seeing it. Good luck
2helpful
How to change the drive belt on a Toro 20016 SP Mower
The Toro 20016 mower is a front wheel drive mower and fairly simple to change the belt on. Start by disconnecting the spark plug to prevent start ups while working on the machine.
Remove the blade and adapter. The adapter includes the pulley for the belt.
two screws under the mower, with 3/8 heads hold the black cover over the belt. remove the cover and now you will see the transmission
The transmission, depending on the year of your machine will have a guard holding the belt on. Bend or remove the guard to remove the belt. Install you belt in reverse order.
You can get parts and special tools like the blade stop at a store like www.arcolawn.com
1helpful
I have a toro lawn mower. Model no. 20352. The drive belt came off the pulley. How do I reinstall?
Go to this URL:
https://icontent.toro.com/smartmanuals/22Recycler/Proc10806.htm
On the left side of the page there are a few items for maintaining your mower. One shows how to change the drive belt for a front drive and one shows for the rear drive. Click on the one you have and it will show you how to accomplish this task. Be sure to either tighten the belt so it does not fall off again, or if it is bad, replace the belt. Please follow all safety instructions.
1helpful
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Top Garden Experts
Jay Finke
Jay Finke
john h
