20 Most Recent Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower Questions & Answers
go to youtube they have videos on how to adjust governor
Toro 42 In Deck... | Answered on Nov 19, 2018
runs for too long to be a fuel problem
more like an overheating electrical component or voltage falling too low to run the ignition system
Toro 42 In Deck... | Answered on Sep 29, 2017
Remove foreign debris from tire and install proper size tube.
Toro 42 In Deck... | Answered on Sep 10, 2017
Could also be a carburetor issue, remove air filter and make sure that its not clogged, even try running it for a short time under the same load. If problem persist tske it to rdpair shop bc there are several other issues it could
Toro 42 In Deck... | Answered on Jun 09, 2017
Is the unit new? I saw a situation where Lowe's forgot to attach the steering arm. Then again, your pressure release valve (what allows for free manual movement) may be open.
Toro 42 In Deck... | Answered on Oct 17, 2016
Check the drive belt underneath is not loose and slipping.when engaged.
Toro 42 In Deck... | Answered on Sep 25, 2016
Elertric blade drive clutches are a real pain when they go wrong
It sounds like a electrical short is causing the wires inside the switch to heat up beyond the safe melting point thereafter five mins the circuit gets between the fault gets broken as the switch fails the blades stop and the switch melts a bad eaRth corroded may cause this check the deck safety switches are not exposed e.g. they been damaged and the decks metal is shorting them out
a wire has been stripped of protective covering and is touching some metal shorting out something that vital to the blade controls operation the switch is getting a overload and subsequently melting your might need an lawnmower engineer to diagnose to the fault fully and repair
Toro 42 In Deck... | Answered on Jul 04, 2016
sounds like you are on the right track, I would replace the needle and seat and also check the roll over solenoid that is on bottum of float bowl, some times they go bad and do that. and they have also had issues with needle and seat not sealing,. some people have put shut off valves on their line and turn it off when not using hope this helps you, don't forget the thumbs up!
Toro 42 In Deck... | Answered on Jul 03, 2016
How to test a solenoid....
How to test lawn mower solenoid
How to test lawn mower electrical safety switches....
Shows all safety switches disabled....
Disable all lawnmower safety switches
How small engine governors work....
https://www.youtube.com/watch?v=50WipK9L8hc&nohtml5=False
Toro 42 In Deck... | Answered on Apr 27, 2016
sounds like the coil is breaking down at high temperature. make sure the engine is not covered with grass clipping and dirt. replace the coil. i think this will solve your problem
Toro 42 In Deck... | Answered on Mar 19, 2016
Something is jammed in the drive and when you put the mower in gear the motor stalls. U need to locate the source of the problem - once you do that all will be copacetic.
Toro 42 In Deck... | Answered on Oct 29, 2015
How long has it been since last running? Are all the safety switches activated? Handles pushed back all the way? Sitting on seat (i presume) ? Parking brake engaged? I would also check the oil. What does the oil look like?
Toro 42 In Deck... | Answered on Sep 30, 2015
There are adjustments for this problem on each side of machine. Just follow the arms and you will see. This happens due to vibration. GOOD LUCK FRIEND.
Toro 42 In Deck... | Answered on May 28, 2015
check for spark is the wire on the spark plug is the plug good check for fuel flow possible electrical short
Toro 42 In Deck... | Answered on Apr 28, 2015
First, make sure the steer stick in moving the lever into reverse. Please check this with the engine off
Second, Check the belt tensioner. Sometimes they end up stuck which has been known to cause the belt to slip on the left transaxle only.
Third, buy a new transaxle...
Next time, include model number for a more precise answer
Toro 42 In Deck... | Answered on Apr 14, 2015
Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower Logo
173 questions posted
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
roeb
Marvin
Marvin
Are you a Toro Garden Expert? Answer questions, earn points and help others
View Most Popular
Toro Garden
  • Toro Garden
Most Popular Question
adjust valves 19hp kohler sv590 engine
  • Garden
