Electrical Supplies Logo
Kelly George Posted on Oct 01, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My balboa tub wont heat more than 75 degrees I keep changing it to ST mode but it wont increase to the set temp which is 103.
Have tried flipping circuit breaker going thru all the modes several times,
Gene Haynes
Level 3:
  • Master 5,391 Answers
  • Posted on Oct 28, 2019
Gene Haynes
Master
Level 3:
Answers
5391
Questions
0
Helped
2606697
Points
14124
Contact balboawatergroup.com and ask them about the thermostat ... thermostats come out of calibration ... and the thermostat might be a simple replacement item, especially if the water is heated with electric elements and not gas...
5 Related Answers
Anonymous
  • 290 Answers
  • Posted on Nov 20, 2007
SOURCE: Ruud heat pump outside unit trips circuit breaker
Check your wiring between the contactor and compressor for a short to ground, or check the compressor windings for short to ground.
With the Tstat off, the contactor should be open so the only way for the compressor to be trying to do anything is if the 110 volts from the unbroken side are traveling through the compressor to ground. Since 110v is not enough to run it, the overload is kicking it out, cooling off, and repeating the cycle. When you kick on the Tstat, the contactor is supplying voltage directly to ground without going through the resistence of the compressor windings and kicking the breaker.
Post back and let me know what you find.
Anonymous
  • 37 Answers
  • Posted on Dec 10, 2009
SOURCE: How to Get Hot tub off sleep mode
press temp button and then the light button in sequence.
Ian  Hot Tub
hot tub plus
  • 77 Answers
  • Posted on Apr 01, 2010
SOURCE: When I change the temp. setting it keeps heating at original temp
The keypad appears to working correctly.
When you alter the set temperature via the keypad the display will flash the temperature thats to be acheived, once it stops flashing the keypad will revert back to the current temperature of the water.
Hope that helps,
Ian.
http://hottub.synthasite.com
Anonymous
  • Posted on May 23, 2010
SOURCE: Fan works, but Oven stays at 100 degrees. Tried
On my C301 U, I found the brown connector on the right side of the oven control board P3-2 loose. It looked connected but while doing a shake test- Whoop, there it is. It is the sensor for the temp probe. If it's loose all the fans run all the time.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=C301U&productCategoryId=0124100&brandId=1085&brandDescription=THERMADOR&modelName=BUILT-IN-OVENS&diagramPageId=00014&componentDescription=WIRING%20DIAGRAM&documentId=U2500861&blt=06
Anonymous
  • 1325 Answers
  • Posted on Oct 15, 2010
SOURCE: inquiring for circuit board shematic
i hope its a schematic to a chip (TEXAS INSTR).. if it is here you go !
http://www.datasheetarchive.com/ST103%2F6-datasheet.html
2answers
Great lakes hot tub heater control not responding
Check the thermocouple on the water pipe.
Jul 16, 2022 • Pool & Spa
Caldera olympia spa need to increase temperature but keep going back to 60 degree reading even though it says 103
suspect is a faulty water heater. check temp where heated water returns to tub.
Nov 11, 2018 • Pool & Spa
2answers
Balboa hot tub.. how to turn up the HEAT / TEMP , no owners manual, and does anyone know where I can get one?
You do not have a Balboa Hot Tub. That is the company that made the control panel for it. Id venture to guess it's either a Hawkeye, Barefoot or Master spa if it came with no owners manual. To turn up the heat simply press the Red "up" arrow on the digital control pad. Check out the link below. It's a quick reference guide to what I'm guessing is your top side control.
http://www.hawkeyespas.com/pdf/balboa-504-topside.pdf
Apr 22, 2013 • Garden
Not sure how to get balboa hotub off of Econ mode and to get it to heat up
use the Mode button and either the temp up or temp down button to change the setting on your tub from econ to std.
Rod
US Parts Center
888-521-6183
Feb 03, 2013 • Pool & Spa
6helpful
Tub is not heating to temperature and flashing a Ec message on the temperature screen.
the Ec message is reffering to the mode the tub is set for. Ec stands for Economy mode. In Economy mode the heater will only come on during the filter cycle you have programmed. It will take a while for the tub to actually heat up in this mode. Change the mode to St mode which stands for Standard mode. Your manual should explain how to do this. usually you hit the temp button then the light button to change from mode to mode. Once the St is in the read out window don't touch anything and it will except the programmmed entry automatically. In the Standard mode the tub will keep heating until the set temperature is reached. then it will come on every half hr or so to check that the temperature is maintained.
16helpful
2answers
Hot tub stuck in 'SL' mode
Need to know what buttons your topside control has... depending on the model, some have a mode button which you press and release and then immediately press the temp up or down, to select SL for sleep (no heat), ST for standard (heat as needed) or EC for Economy (only heat during filtration). If the mode button is not present, and you have a single temp button and light button, try pressing and releasing temp and then immediately pressing light button, repeat until choice appears, then wait, it will hold last displayed mode.
64helpful
2answers
27helpful
4answers
OC hot tub is getting SL error and does not heat. Model is M-09-MOC1545-3. Recently purchased and lost manual. Thanks.
sl means sleep mode and will not heat! try depressing the temp button the either the light button or the jet button usually that will change modes u want st or std mode which means standard. or if u have a mode button try that 1st. or email me a copy of control head to [email protected] for tips! thanks Bob
Hope that helps,
Ian.
Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
