20 Most Recent Kohler 14resa 14kw Home Emergency Backup Generator Questions & Answers
I have a locked rotor fault message.
I had this fault show this morning. Very alarming, as we have a typhoon coming theough tomorrow! Turned out to be an easy fix. When I hit start the solenoid engaged but nothing moved. Then I saw the fault message and thought "Large $$$$!" It was just a bad 12 Volt battery, and when it couldn't crank it threw the fault code. I replaced the battery, pulled the 3 fuses on the control panel (mine is the 20 Kw model), and the codes cleared, and she fired right up. The advice here and on a couple other sites about powering down the panel to clear fault codes saved me a lot of time, money and aggravaion, not to mention a freezer full of food (knowing the Guam Power Authority, and knowing typhoons, the power WILL go down tomorrow.
10/26/2021 9:24:03 PM • Kohler 14resa... • Answered on Oct 26, 2021
14kw kohler propane generator-sometimes does not start, put battery jumper on and it starts. Battery is new, but had the same problem with the old battery.
The battery charger is defective, as you can start it by jumping it off means it is just a low battery. without it running measure battery voltage, it should be around 12V then plug the charger back in, it should climb to around 13.8B with a good battery. If not have the float charger checked.
11/22/2013 1:35:45 PM • Kohler 14resa... • Answered on Nov 22, 2013
Why is alarm kohler engine Error code 0094 18
Please see; https://www.fixya.com/support/t25551059-kohler_generator_engine_fault_code_0094
4/20/2024 7:29:35 AM • Kohler... • Answered on Apr 20, 2024
How to wire a Kohler generator starter
8/5/2023 12:31:54 AM • Kohler... • Answered on Aug 05, 2023
My Kohler 35RZ generator Auxiliary Faults on startup after a rain storm. It Otherwise starts right up and runs. .
That is the specific use of WD40. Spray it when it is warm and the kerosene will evaporate and leave the waxy protective coating behind.
1/25/2023 11:41:58 PM • Kohler... • Answered on Jan 25, 2023
20 kw RESA Kohler Generator " locked rotor " problem where do I start. New battery as been installed
You need to repair your locked rotor then it will work
12/19/2022 7:51:01 AM • Kohler... • Answered on Dec 19, 2022
Kohler 14resa gen just stopped running no spark, changed out ign coils still no spark.
not car moved yah lost the users manual??? in it is the schematic, and on said schematic is what kills spark dead. 1: oil switch bad. 2:kill switch bad. 3: wires too those cut or shorted. it's all there to read, ask maker for the lost manual
12/11/2022 6:48:59 PM • Kohler... • Answered on Dec 11, 2022
I have a Kohler Model 4.5 CKM 21-rv How do you check the voltage regulator # C 239311
Don't think you can check the avr it's self (capacitors you can) there are continuity tests you can do to the windings of the generator to determine a fault with that if that all checks out ok the avr is at fault
11/12/2022 8:28:44 PM • Kohler... • Answered on Nov 12, 2022
I have a generator 55kv hi volt 460 what is the problem
depending on the machine Could be the Rpm to high
11/12/2022 8:20:43 PM • Kohler... • Answered on Nov 12, 2022
2answers
What is the fix for a locked Rotor code on my Kohler 14 RESA generator?
Hi, if possible please check your speed sensors within your generator to make sure each is still functioning properly. Otherwise, you might have to replace the sensors before the code goes away. Thank you.
10/20/2022 11:21:08 PM • Kohler... • Answered on Oct 20, 2022
2answers
Aux fault on Kohler generator 5ekd says 17.0 fault check engine
More supports or if you consider diesel generator set in furture, please contact [email protected], or visit at: www.dieselgeneratortech.com
10/12/2022 3:12:06 PM • Kohler... • Answered on Oct 12, 2022
Kohler 5ecd generator giving high battery voltage alarm
Fault code is displayed if the engine starting battery voltage rises above 16 VDC for a 12 VDC system or above 30 VDC for a 24 VDC system for more than 2 seconds when the engine is not running. This fault condition does not inhibit engine starting. The fault condition clears when the battery voltage returns to a voltage within the limits for more than 2 seconds Check the battery rating and condition.
10/12/2022 2:42:21 PM • Kohler... • Answered on Oct 12, 2022
I have a kohler 5E generator has SPARK only on one side
Kohler 5e Marine or mobile/Generator?????? working on this lacking a meter and manual. ? working blind I call it. not good that ever. call for help: it has 2 coils, 2 sparkplugs 2 HV wires to fail, (1 of them) and 2coil igniter we use and ohmeter to the bad coil. primary is of coil (ignitor end) is about 5 to 12ohms. (infinity bad) secondary coil is high ohms 1000 to 10000, par, infinty bad. the HV lead is used to measure secondary to coil core metal the HV lead can fail too. making coil useless. and last a bad ignitor , the 2 coils are same P/N so can be swapped and if failure move to other plug, bingo for bad plug , otherwise bad ingnitor box.
9/20/2022 2:15:49 PM • Kohler... • Answered on Sep 20, 2022
Kohler House Generator powers up when our electricity goes out but then powers right back down?
That is an engine running issue, not a battery issue. :>D The first thing to check would be fuel supply. Can you start up manually and keep it running. If you can, it is the contactor that senses your loss of mains power and switches the generator on. It is not maintaining the connection, or is is misdiagnosing the power from the generator as power from the mains.
8/31/2022 11:40:03 PM • Kohler... • Answered on Aug 31, 2022
2answers
Kohler Confidant 5 Generator. I put in new spark plugs and gas line. It runs but will not put power in motor home. How to change or check brushes?
Question edited for clarity. Two duplicate Questions deleted and amalgamated into one question. Refresh the page to see your question published. Help in the link, it is common. https://www.google.com/search?q=Kohler+Confidant+5+Generator%2C+no+power+output ..
8/31/2022 7:10:22 AM • Kohler... • Answered on Aug 31, 2022
2answers
What is maximum that discharge water should be for a gasoline Kohler marine generator 7.5
the water pump decides that and not told that. maker nor model 7.5 means kilo watt, KW. of energy;. for gen or 7500watts a pump less that that can push a lot of water GPM gallons per minute,but have not idea what you are doing.
8/16/2022 11:07:03 PM • Kohler... • Answered on Aug 16, 2022
Kohler 14resa 14kw Home Emergency Backup Generator Logo
Popular Tags
8 questions posted
Top Kohler Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kohler Electrical Supplies
Most Popular Question
  • Electrical Supplies
