20 Most Recent Honda 6370C - Parallel Power Kit For EU3000i Questions & Answers
3answers
Honda EU3000is Generator is running poorly.
Can anyone help me with the eco-trottle switch when I switch it on it seems to run the same idle whether I have it off or on, what could be causing it not to work, is it a bad switch or I am running 89 octane could that be the problem.
Thanks
Alex
12/16/2022 4:36:38 AM • Honda 6370C -... • Answered on Dec 16, 2022
7answers
Honda EU3000is generator will not start with electric starter.
I'd say your battery in the generator is going bad or bad. They are very small and do not hold a charge for very long. The noise you heard was probably the starter shaft hitting the flywheel cogs. I doubt any harm was done as long as you did not repeatedly try to start it with the key. Why Honda put a battery in these is because they are intended for use in a campground setting, where they would be used on a daily basis and the battery would constantly charged. Whereas people like us buy them for emergencies only, they sit for long periods, and the battery goes flat, and the fuel clogs the carb and we get the surging issue. That's my 2 cents. When I brought mine home new, I Sta-bil'd the heck out of the gasoline, this past winter, on start-up, the unit surges. Of course the battery was flat.
2/22/2022 3:41:23 AM • Honda 6370C -... • Answered on Feb 22, 2022
8answers
Honda EU3000IS Generator Surging / Pulsing Problem
There is an upright small pencil diameter sized fuel screen inside the fuel tank of the EU3000is. I went in through fuel filler opening on the the top of the unit with a tooth brush on a stick and cleaned the screen. I then siphoned the rust and dirt particles out of the tank. Doing it this way precludes the necessity of draining the tank. My 3000 has been working smoothly since. If the problem reoccurs, repeat the process.
10/13/2019 11:51:01 AM • Honda 6370C -... • Answered on Oct 13, 2019
Honda eu3000is won't start with starter.
replace the 20 amp fuse that is inline to the starter. you will find it wired in above the battery.
2/11/2018 1:10:38 AM • Honda 6370C -... • Answered on Feb 11, 2018
The remote start for my honda eu3000is will not shut it off
Bad earth connection to the key switch as these magneto types only earth the coil wire to turn ignition off. Check for loose connections or faulty switch
2/7/2018 6:55:50 PM • Honda 6370C -... • Answered on Feb 07, 2018
I just bought a new honda 3000 generator and started it for the firs time and the electric switch doesn't work
Do not fiddle take it back for warranty repairs
2/7/2018 6:39:41 PM • Honda 6370C -... • Answered on Feb 07, 2018
4answers
No power output from a generac c5000 generator
First check the circuit breakers on the control/outlet panel.
Then take the end off the generator and look at the brushes (usually what breaks) and the 2 slip rings they ride on (these get dirty and have to be cleaned off with a bit of emery cloth)
Then look at the voltage regulator (the little board that the brushes plug into)
Let me know if you need more detailed help,
Carl
11/16/2016 7:47:21 AM • Honda 6370C -... • Answered on Nov 16, 2016
Need owners manual for 11 hp honda gx430 on a pressure washer
Honda Engines Small Engine Models Manuals Parts Resources They have all the engines there. They don't however have the GX430 They have other models that might be close to yours. Hope this helps.
6/7/2014 5:04:31 AM • Honda 6370C -... • Answered on Jun 07, 2014
EU3000is running rough and idle hunting.
I'VE SEEN THIS BEFORE ON 1 I REPAIRED IT IS THE INVERTER THAT IS BAD!!! THEY COST ABOUT $600.00 JUST FOR THE INVERTER!!!!
1/1/2014 2:57:21 PM • Honda 6370C -... • Answered on Jan 01, 2014
Honda eu 2000 generator surging
remove the throttle control motor spin motor a few times. I believe due to the minimal rotation required during activation a flat spot or build up results in a poor connection. Kicks down under load now. Back to the smoothnes of a new unit
3/17/2013 7:22:53 PM • Honda 6370C -... • Answered on Mar 17, 2013
Honda 6370C - Parallel Power Kit For  EU3000i Logo
65 questions posted
Top Honda Electrical Supplies Experts
vince
Paul Carew
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Honda Electrical Supplies
Most Popular Question
need owners manual 11 hp honda gx430
  • Electrical Supplies
