20 Most Recent Generac 13,000 Watt / 13,000 Watt Home Standby Generator Questions & Answers
I have a generator that did the same thing. It would start and then stop within a few seconds. The more expensive generators have an oil level safety switch to prevent the engine from burning up. There is usually a wire connecting to the switch on the outside of the engine near the oil fill hole. Remove this wire and try to start the generator. If it runs without a problem then it is the switch. You need to remove the switch and take it apart carefully and clean it. There is a small float inside the assembly. When the oil runs low the float allows the switch to short to ground which kills the spark to the spark plug. Hope that helps.
Bob Janelli
I’m happy to help further over the phone at https://www.6ya.com/expert/bob_62dfa2f81bb55288
Generac 13,000... | Answered on May 19, 2018
Overcrank means that it tried to start and couldn't. It will go through 5 crank cycles and then stop with this alarm. Switch to off, hit enter to clear fault and then try to start in manual. Check to make sure you have fuel and pressure is 11 to 14 in WC.
Generac 13,000... | Answered on Mar 24, 2018
need to calibrate the main control board. 83089. also is it overspeed or overcrank? if the board does not see the right rpm or is blow a certain threshold it will think it has not started yet and shut down on overcrank.
Generac 13,000... | Answered on Nov 08, 2017
How old is it???? Does it have a read out that tells you what's wrong?????When is the last time you did a maintaince tune up on it???? Mine is fueled by propane and I changed the oil and plugs and it's been fine since....Sometimes it's the starter/ignition..I would do a complete tuneup first, then clear codes, then try starting it up manually....If that works put it back on auto..Good Luck
Generac 13,000... | Answered on Apr 09, 2015
If it was installed only five months ago, it should still be under warranty. Call Home Depot and have them send out a repair person.
Generac 13,000... | Answered on Mar 02, 2015
Are you sure about that model number?
Generac 13,000... | Answered on May 06, 2013
For the over voltage there is an adjustment on the control board.
Should be tested with a load something plugged in.
The hertz might just come on when under load and adjusted too.
If you need more give a model number and whether it is 13kw or 40kw.
Generac 13,000 Watt  / 13,000 Watt  Home Standby Generator Logo
86 questions posted
Top Generac Electrical Supplies Experts
Sheldon Dedek
Bob Janelli
Level 1 Expert
Craig Butler
Craig Butler
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Generac Electrical Supplies
Most Popular Question
natural gas generac 8kw running fine now
  • Electrical Supplies
