20 Most Recent
Balboa Instruments Duplex Digital Panel 2 Pump Questions & Answers
The instrumentation panel says "SL" and the spa
You have it in "Sleep" mode. Spa will not heat normally in this mode...
If the SL Message is Alternating with the Water Temp in the Display Screen (we call this "Flashing Sleep"), the Spa is Operating in the Sleep Heating Mode.
If the SL Message is ON Solid (Not Flashing) in the Display window of the panel, the Spa is Operating in the Sleep Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
SL or SLP is one of the Modes you can program your spa into:
EC - Economy
ST/Std - Standard
SL/SLP - Sleep
It is advised you keep your spa in Standard mode. Push the Jets button then immediately push the light button. Each press of the light button will scroll between these three modes.
Good Luck
11/4/2022 8:35:54 PM •
Balboa...
Answered
on Nov 04, 2022
Balboa Hot Tub (topside) control panel.
Hold temperature UP & DOWN together for 6 seconds.
or
Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
2/18/2018 5:35:08 PM •
Balboa...
Answered
on Feb 18, 2018
Instruction manual for balboa vs5000 spa
I have a Clearwater Spa with a LM8000 spa pack that the control module does not work. Can I purchase just the control module or do I have to replace the complete system? If I need to replace the complete system what system can I replace it with?
7/13/2017 3:22:26 AM •
Balboa...
Answered
on Jul 13, 2017
Hi, i got a used Manhatten Catalina Spa from a
Check to see if something inside the control panel circuit board came apart or broke from being moved. These things were not designed to be moved around a bunch so you probably have a soder joint come loose or get disconnected.
4/19/2017 12:23:02 PM •
Balboa...
Answered
on Apr 19, 2017
I have power to the spa, but it won't power up
there are at least two separate circuit breakers feeding your spa and two reset buttons. the circuit breakers are located a few feet away from the spa in an electrical box.
the reset buttons are in the mechanical space of the spa where the pump and heater are located.
12/29/2015 1:14:42 AM •
Balboa...
Answered
on Dec 29, 2015
My Balboa 500Z-Series Hot tub
Hello!
I have a question about my Balboy 500Z. When the water is heated the motor pump is still running that means the pump runs all the time without interrupt even the water has it's temperature. Now my question: is it possible to turn of the pump? thank you for your quick answer! Greetings Beat from Switzerland
10/23/2015 5:41:27 AM •
Balboa...
Answered
on Oct 23, 2015
My catalina spa keeps popping the breaker and won't turn on
First, we have to establish what you mean by turn on the unit. Is the GFCI breaker set on when you try to turn the "unit" on? What are you activating to turn the "unit" on? A switch, a disconnect, a button on the topside controller, etc.? Need clarification before we proceed to diagnose. At what level do you understand electricity? Is there a licensed electrician available?
Please answer and we will take it from there. OK?
7/16/2014 12:09:20 AM •
Balboa...
Answered
on Jul 16, 2014
