I am assuming you have a water line dedicated to the fridge for the ice maker. If the fridge has a water dispenser, make sure water is flowing from it. If no water is flowing, make sure the water line was not shut off (check the shut off valve usually where the line connects to the main water source. Also make sure that there is no electronic sensor or switch enabled that turns off the ice maker.
SOURCE: Ice Maker
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
SOURCE: Light blinking on ice maker control switch
The red light on the right side of the freezer at the on off slide mechanism is normal and ok. I indicates the ice maker is not in a cycle at the time. It is not meant to tell the customer the unit is ok or it is not ok. Ignore the light.
If I helped enough please don't forget to rate as a FixYa if you need more information please request more help.
Thanks, supertechks
SOURCE: Kenmore Elite ice maker is not working & red light is blinking
Most likely a problem with the main ice making unit itself. I bought mine at ebay for $49 including shipping. Very simple to replace. You just swap the wiring harness and bottom plate. Takes about 20 minutes to do.
Make sure you do the IR led test. If you think you IR sender and receiver are bad to, $57 on ebay for the set. Most likely not your water solenoid in the lower back of frig (it gets the signal to turn on from the receiver module of the IR board.
Probably not your water filter (cuz the front water dispenser still probably works right?)
And probably not a clogged or frozen line.
Good luck. When it doubt, trust ebay!
Hi, It's supposed to do that. Fill the base with water, then select an ice cube size, then click "start". It should start making ice within 20-30 minutes. The power goes off here all the time and that's how we re-start the machine. The important part is to first select the ice cube size, then click on "start'. I have no idea why it has to be done in that sequence. I have the same model, only I got it two years ago.
