20 Most Recent
GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW Questions & Answers
Leaking icemaker
It sounds like your water valve is occasionally get stuck open and over filling the icemaker.
Water leaking around water filter
Filter housing probably has a cracked or bent o-ring. Put some food grade lubricant around the o-ring. If that does not help, replace the o-ring.
Freezer thaws and then Refreezes
Theory of operation: Cold air is produced in the freezer section and is then circulated via a fan located in the freezer section. It sounds like you may have either an air leak from faulty door seals, ice dispenser door flap stuck in the open position, or the light staying on the door is closed.
A faulty compressor fan may also cause symptoms like that but you should hear the thermal cut out clicking off and on due overheating of the compressor. I’m happy to assist further over the phone at
https://www.6ya.com/expert/david_dc2f9e0a44104720
I HAVE A 21 YEAR OLD GE FRIG SIDE BY SIDE MOD. #
You are correct -Temps not low enough and you have been thorough in checking things out. About the only thing I can think of now is to make sure that the condenser coils underneath are perfectly clean to promote max efficiency. If clean, and we know your compressor is running after all these years You may be, yipes, low on refrigerant. I am sure you have thought of that but did not really want to deal with it - don't blame you. If you want to pursue that venue it is a PIA but can be done, CAREFULLY because the freon level on refrigerators is a critical parameter, not like a room or car AC. If wanna try relist your question as DIY refrigerator charging.
GE Profile REfrigerator: Model
i have same fridge with same prob makes 6 cubes of ice in a day with a lot of noise like you discribed also i have water collecting under crisper drawer of fridge i have to clean out water once a month or so still trying to figure out how to take ice maker out to fix
Ice maker stopped working
The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
Flap won't stop humming buzzing
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls
·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open
·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset
·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Refrigerator will not freeze
Check for ice on back wall of freezer. If there then the self defrosting mechanism is not working. If all systems are go then check for leaking door gasket, bad thermostat , and low gas situation.
