20 Most Recent Polar PIM15W Ice Cream Maker Questions & Answers
7answers
Polar Ice Maker Portable
there is a little sensor inside on the top right, it is a little wire if there is anything on it it will not work, i took at small pair of pliers and gently cleaned it
8/19/2017 4:36:23 PM • Polar PIM15W Ice... • Answered on Aug 19, 2017
How to put refridgement in my polar icemaker
Hey, a new word, "refridgement".
5/15/2014 3:58:10 AM • Polar PIM15W Ice... • Answered on May 15, 2014
Polar Ice maker says low water level when full of
Replace the motor. During the cycle of the unit if the water flow circuit does not scence flow, the unit faults with a low water indication
6/23/2010 12:33:06 AM • Polar PIM15W Ice... • Answered on Jun 23, 2010
2answers
Ice maker don't make ice, the three red lights just keep on blink
Hi, The water tray on the machine is probably broken where it connects to the motor. I have the same problem, and am trying to reach Greenway to see if I can get a replacement part. this seems to be a common problem with this ice maker.
5/4/2010 8:22:16 PM • Polar PIM15W Ice... • Answered on May 04, 2010
2answers
Polar ice maker model PIM15W
Try Greenwayhp.com look under replacement parts page 3.....The gim15 tray is the same........
4/6/2010 7:24:20 PM • Polar PIM15W Ice... • Answered on Apr 06, 2010
I NEED A HB1114 ICE CREAM MACHINE MANUAL
https://www.manualslib.com/i/ichb1114e+cream+maker.html Try this site. Let me know if it works.
12/4/2023 12:34:16 AM • Ice Cream Makers • Answered on Dec 04, 2023
What is the black liquid draining into the ice-cream canister from the motor while making? And is it still safe to eat?
No make and model provided but.... Of course it isn't safe to eat!! It is likely a mixture of oil, broken seal dust and a little metal/rust creamed with a drop of condensation. 50 years as as a chef and I wouldn't serve that or eat it. Fix it or thrown the machine away! These machines are normally 20 years old and get used 3 times every 2 years.
7/5/2023 12:17:35 AM • Ice Cream Makers • Answered on Jul 05, 2023
Ice cream maker freezes and stops turning after only 20 minutes. I set the time for 60 minutes.
If your ice cream maker freezes and stops turning after only 20 minutes, there may be a few reasons for this. Here are some things to check: Freezing temperature: Make sure that the temperature in your freezer is set to the correct temperature (around 0°F or -18°C). If the freezer is too warm, the ice cream maker may not freeze the mixture properly. Mixture consistency: Make sure that the mixture you are using is not too thick. If the mixture is too thick, the ice cream maker may struggle to turn the mixture and freeze it properly. Overfilling: Make sure that you are not overfilling the ice cream maker. Overfilling can cause the mixture to overflow and prevent the machine from freezing the mixture properly. Motor issue: If none of the above solutions work, there may be an issue with the motor of the ice cream maker. In this case, you may need to contact the manufacturer or a professional repair service to diagnose and fix the problem. As for turning on the furnace and power in your Hitchhiker II trailer, you may need to refer to the owner's manual or contact the manufacturer for specific instructions, as the process may vary depending on the model and year of your trailer.
2/24/2023 9:22:15 PM • Ice Cream Makers • Answered on Feb 24, 2023
How can I replace the fuse 16A 250V in my Buffalo Icecream maker ?
I have no idea. Are you an electrical engineer ..............
10/22/2022 7:19:14 AM • Ice Cream Makers • Answered on Oct 22, 2022
Anyone to help me with manual for Beiqi ice cream machine (model BQ323PA)
It appears to be a South African machine, so this link might work better for you than me in North America. https://www.google.com/search?q=Beiqi+BQ323PA+manual ..
10/5/2022 12:30:41 AM • Ice Cream Makers • Answered on Oct 05, 2022
Is cream charger necessary for making coffee?
There is no substitute for a cream whipper when it comes to making foams, sauces, and freshly whipped cream. These sealed canisters whip up whipped cream of the highest caliber in a matter of seconds by forcing air into the cream using compressed gas. These instruments are necessary for caf?s, bakeries, restaurants, and more since they let you to make a variety of desserts, milkshakes, fresh cakes, pastries, and cream infusions. However, how can you maximize the potential of your cream whipper? Cream whippers, which are most known for creating whipped cream that maintains its shape and texture, can also keep foams, sauces, and mixes fresh by delaying the start of oxidation. What happens if the multipurpose kitchen appliances you rely on suddenly break down? Fortunately, most problems can be swiftly resolved, so knowing how they operate will help you improve their performance when the occasion demands it.
9/14/2022 6:05:38 AM • Ice Cream Makers • Answered on Sep 14, 2022
Cooks essentials 700 ml ice cream maker
limited info generic answer circuit problem -paddle connection fail--cog/gear fail -motor fail need to examine unit to narrow down problem since their many to choose from
8/1/2022 2:46:33 PM • Ice Cream Makers • Answered on Aug 01, 2022
Can anyone help me get my Taylor 150 Ice Cream machine started please?
If it was fine before stored away, then either the power is not getting to the machine, (rodent damage or corroded contacts) or there is a control fault.
7/16/2022 5:58:26 PM • Ice Cream Makers • Answered on Jul 16, 2022
Instructions and recipes for Toastmaster ice cream maker
The manual is here
Toastmaster Ice creamn maker model 6701, use and care ...
https://manualzz.com > ... > Ice cream makers Toastmaster Automatic Ice Cream Maker Use and Care Guide Recipe Book Model 6701 IMPORTANT SAFEGUARDS When using electrical appliances, basic safety .. ..
7/14/2022 7:55:41 PM • Ice Cream Makers • Answered on Jul 14, 2022
I have the presto ice cream now maker model
Did you ever get the directions? I have the booklet but can't use the ice cream maker because it is missing the lifting ring, no longer available.
8/25/2021 2:28:53 PM • Ice Cream Makers • Answered on Aug 25, 2021
I need a manual for the sevoureux ice maker
Contact Sevoureux directly to request the manual.
3/21/2021 5:18:06 PM • Ice Cream Makers • Answered on Mar 21, 2021
Polar PIM15W Ice Cream Maker Logo
Popular Tags
14 questions posted
Top Polar Ice Cream Makers Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Polar Ice Cream Maker Expert? Answer questions, earn points and help others
View Most Popular
  • Polar Ice Cream Makers
Most Popular Question
polar ice maker says low water level
  • Ice Cream Makers
