Tip & How-To about Refrigerators
Ice Maker Problems and Ice Maker Troubleshooting
Always remember to unplug your appliance before you work on it to prevent injury. Also be careful of sharp edges while working on appliances.
There are three common things that go wrong with Ice Makers.
  1. No iceā€¦ If your ice maker has stopped making ice then you need to check these things.
    1. The lever that controls the ice maker has been pushed up which turns it off. If you have a red lever, pull it down to the wire and if you just have a wire then just pull down the wire to start your ice maker up.
    2. Make sure the freezer temperature is below 10 degrees F If the freezer is too warm ice production will be poor because the ice maker will not cycle properly.
    3. The ice maker fill tube may have ice formed in it, blocking it. Use a hair dryer to melt the ice. Watch out for the plastic parts, so that you do not melt the plastic. Also check the water inlet valve and the shut off valve, to make sure it is not plugged with debris. The openings in those valves are very small.
    4. Check the gears in the ice makers to see if they are broken or stripped. Also look to see if the ice rake is broken. All parts in the ice maker are replaceable individually, If you find broken parts replace them.
  1. Small or not enough ice cubes
    1. Here again check the water lines and the valves for blockage or restrictions.
    2. Check the Ice maker mold thermostat to see if it is cycling properly.
    3. Check the temperature of the freezer. It should be below 10 degrees F
  1. Specks in your ice cubes.
    1. This is often caused when the protective coatings inside the ice maker start to peel away. The coating is harmless but does not look very good and will eventually cause a failure of the ice maker to operate properly. If this is happening you will need to replace the ice maker.
This will help you to figure out the reasons why your ice maker is not making ice or you are not getting satisfactory performance from your ice maker.
Refrigerators Logo
Our freezer section does not get cold enough to freeze, nor does our refrigerator section temperature get below 55 degrees. Do you have any suggestions?
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
You need to check the temperature settings and see if there is enough air flow in the refrigerator and freezer. You need to check for air flow restrictions in the vents and clean the compressor coils. The door seals, door switch, defrost heater and timer has to be checked. Also clean the clogged drain tube and refrigerant leak.
I hope this will help in solving the problem.....
We have water om the floor under the laft fronmt corner of our fridge/freezer . Model tbx 22pr
WHAT IS WRONG WITH YOUR REFRIGERATOR?
small_4_1.jpg For a detailed Refrigerator illustration, click below.
redarrow.gif Side by Side
redarrow.gif Freezer on Top
redarrow.gif Freezer on Bottom
redarrow.gif Under counter
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Try to check the defroster heater this cause the problem;
topload maytag washer partially fills by its self overnight or even a day or two may pass.
Your washer has a defective water inlet valve.
The link below is courtesy of. www.repairclinic.com,
They also provide repair parts, disassembly diagams and procedures.
http://www.repairclinic.com/SSPartDetail.aspx?s=b4a11i868761&PartID=868761
This may not be the exact part for your washer.
You will need the complete model number from the product ID tag which is affixed to your washer, to obtain the correct part.
TIP:
If it is convenient, it is advisable to turn your washer faucets off when not in use, to prevent accidental flooding
how do I shut off the very loud end of cycle sound in maytag ldg8506AAM gas dryer
This buzzer is non-adjustable. Click the link below, provided by, www.repairclinic.com to view this part so that you can identify it in the control panel of the dryer. You can remove the wires from it to make it inoperable. You can also get disassembly instructions at their site.
http://www.repairclinic.com/Appliance-Parts?s=t-ldg8506AAM-%3d%3d&n=5
I am looking for directions for replacing the ignitor for my Whirlpool SF376PEW Gas Range
You will need a product service manual to assist you in servicing the the proper model number of your gas range. Below are 2 links for a service manual.
http://www.servicemanuals.net/service.aspx
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
