Refrigerators Logo
Amy Cline Posted on Aug 24, 2019
Kenmore upright freezer model 253.26052100 is constantly red and temp alarm is constant.
I have unplugged the unit, removed the food and am defrosting. It is currently unplugged. WHat should I do next.
Dave Parker
Level 1:
Habit-Forming:
New Friend:
  • Contributor 38 Answers
  • Posted on Aug 24, 2019
Dave Parker
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
38
Questions
Helped
10652
Points
73
•Make sure that the freezer has plenty of ventilation around it. Some freezers use their outer surface as a heat sink and placing boxes or other objects next to them prevents them from being able to get rid of heat.
•Make sure the freezer is level. Water from condensation needs to be able to drain properly inside the freezer if applicable and having the freezer on an uneven floor can prevent proper drainage of the coils.
3 Related Answers
Anonymous
  • 291 Answers
  • Posted on Jul 08, 2009
SOURCE: Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
Anonymous
  • 4793 Answers
  • Posted on Feb 11, 2010
SOURCE: Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Anonymous
  • 6 Answers
  • Posted on Jun 14, 2010
SOURCE: My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
1helpful
How to resolve issue with Kenmore Freezer #253.21741106 (upright) leaking water and red Temp alarm blinking?
A few things spring to mind.
Failed Defrost timer.
Failed Evaporator fan.
Blocked Defrost drain.
Calling for service is your best bet.
11helpful
2answers
1helpful
Feb 05, 2010 • Freezers
2helpful
2helpful
FREEZER ALARM WILL NOT SHUT OFF
You can try 2 things. Unplug it for about 2-3 minutes and then replug it. It should reset itself. You can silence the alarm or muffle it. Silencing it should be hard. Disconnect it from its source. You may want to find out why it is alarming constantly. Have you called Sears and asked them?
Temp alarm on freezer alarming.
that's the same problem i incurred, i replaced the thermostat and the fan. seems to be working fine.
Defaults to 0 deg. temp
I would be more worried about constant power disruptions
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
1helpful
Kenmore model 2539280412 upright freezer alarm keeps going off
might have a defrost problem check to see if it is building up with on the back panel if it is you need a defrost timer or limiter or heater or fan
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
