20 Most Recent
Kenmore Freezer 14.1 cu. ft. Upright Freezer with Hose Adapter Questions & Answers
What is coldest on the dial 1 or 8
dear sir /madam
please turn to your thermostat nobe clock vise till the end you will got the highest cooling point for lowest turn this nobe anti clock vise position till end it,s lowest point of cooling.
hope answer the question.
please vote!
thank you
The hose that allows water to flow into the ice
You'll need to get a blow dryer and then thaw it out so it can flow again. Move your frozen foods into the fridge while you do this. Let me know what happens. I might have another few ideas. Raz
My upright freezer works great but it makes a
These are the parts that would make a clicking noise. it is up to you to pin point where it is coming from:
compressor
timer
icemaker
fan
ok try to pin point if the clicking is coming from the inside or the outside
you can go to sears.com hit the parts link then enter the model number. you can view a diagram and it will show you where the parts are at
hope this helps
Kenmore Upright Freezer
Control is bad and needs to be replaced. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Error code b on kenmore chest freezer
LOW / NO BATTERY ALARM
The Low/No battery alarm will activate when the
power level of the battery becomes low. The display
will alternate between "b" (Battery, See figure 8) and
the cabinet temperature, the red alarm light will
become illuminated and the control panel will beep
every five seconds. To stop the audible alarm (beep),
press the "ALARM RESET" button. The red alarm
light will remain on and the display will continue to
flash until a new battery is installed. This same alarm
will activate if there is no battery installed
Where is the 9V battery located on a Kenmore upright freezer model 970
The location of the 9V battery on a Kenmore upright freezer model 970 can vary depending on the specific model and design. However, in general, the 9V battery is typically located in the control panel or on the back of the freezer near the compressor. You may need to consult the freezer's manual or contact Kenmore customer support for more specific information regarding your model.
