SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
SOURCE: i have a f725 john deere mower and the mower has
Sounds like you may have a safety switch shutting down the PTO. Check them all as there may be a loose connection.
SOURCE: prob with PTO on craftsman mower 917.273372
There is a idler pivot plate on the mower that must be cleaned and lubricated regularly, from the left side of the mower deck if you look in the middle of the mower deck while someone engages the mower(with the engine off) you will see the pulley try and move,there is a 3/8 bolt that comes up through a bushing that this pivots on, soak that area with wd-40 and see if that improves the movement. Be sure not to get any wd-40 on the belt or pulleys. Always try and keep that area clean and lubed.
SOURCE: the mower turns on fine but when i engage the pto
could have bad pyo switch or pto clutch.make sure every thing turns freely,blades and pullys then unplug clutch and try to enguage if does not blow fuse check clutch with meter. put meter on ohms probe one terminal and other on ground via clutch housing should not have continuety check other terminal to ground.voltage goes in one term and out the other like litebulb if potting (insulator) in clutch is melted wire inside will short on housing.hope this helps
SOURCE: Mower pto engages when initially started but after
the coil in the electric PTO shorts out when it expands by heat causing it to lose it's magnetic pull and disengages- I hate to say it,but you need a new PTO clutch.
