Washing Machines Logo
Posted on Sep 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Leaking westinghouse 9.5kg washing machine
The washing machine leaks slowly at the front right hand corner . It only happpens when the machine is filling with water not during the washing cycle. The machine is 2 years old.
fixrguy
Level 3:
  • Master 415 Answers
  • Posted on Sep 06, 2009
fixrguy
Master
Level 3:
Answers
415
Questions
0
Helped
82692
Points
1311
A hose has partially come off or a cut in the hose
1helpful
Hi my westinghouse 9.5 kg is not emptying the water out completely before spining therefore goes out of balance starts leaking water down in the right front corner also around the seam at the front
indicates that the tub support air dampeners are failed allowing the tub not to be level
normally there is a small amount of water in the tub as the spin starts to allow the cloths to move around for balance but when the air dampeners break there is no initial control for the balance so the tub gets all out of wack
Front loader leaking underneath in the back corner on the left hand side
If its leaking during the fill cycle, its one of the water valves (solenoids) or associated hoses, loose clamps, etc. If its leaking during draining its the drain hoses, pump, clamps etc. Easiest way to tell. Pull it out, if you can remove the back, run it and look for the leak. Just don't touch anything while its running, you don't want to lose a finger or get electrocuted.
My westinghouse leaks water. It's 16 years old, so if it's some major problem I'm ok with it and I'll get a new clothes washer. On the other hand I would like to open up the washer and
The back and sides are one piece. The front comes off (two clips under top, one on each side about 2 or 3" in from outside - two screws on bottom directly below clips). The top will lift up on the rear hinges, the front lifts about 0.5" and comes off.
Westinghouse 522 fridge leaking oil from front right hand bottom corner
Hello, Thank You for using FixYa. I will be helping you today.The only thing that has oil is the sealed system. So if there is oil leaking you would have a leak and the unit will stop cooling.Are you sure something didnt just spill and is leaking out?
Thank You and please rate my answer if it was helpful..
Periodically leaks water from the front, bottom right hand corner where the filter is but filter seal is good.
Question is not clear
Any how try to fix it with some sort of Plastic / Steel Putty like Araldate / Belezona / Devcon / Weicon / Mseal etc ...
2answers
Water leaking on floor at right front corner of
check the door rubber for any tears,this is also called a boot glove.
3helpful
2answers
Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
2helpful
Whirlpool front loading washing machine leaking
you will have to be nice to it as it will come out and with some fairy up liquid you can put it back so easy
Top Westinghouse Washing Machines Experts
ZJ Limited
ZJ Limited
vince
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
