20 Most Recent
Whirlpool AWZ410 Front Load Washer/Dryer Questions & Answers
Hi, I have an AWZ410 front loading washer dryer.
Hello
& Welcome to FixYa
The
problem is with the pressure switch or the control board that is bad and needs
replacement. You have to test the pressure switch, if that is fine then replace
the control board. However, before replacing the board make sure nothing is
blocked in the bottom front panel of the unit which is known as drain pump
filter assembly. Please get back to me if you have any other questions.
Kevin
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
I have Model AWZ410 Washing machine, the washing cycle now takes up to 6 Hours!
i have experienced a machine doing this it was caused by the outlet hose pipe not alined it was syphoning water intermittently so check the hose outlet. 2nd
the wash heater may be open circuit causing the wash cycle to stop, the timer is then manually turned to continue washing .3rd check the pressure switch hose for blockage by taking it off the switch and blowing down to clear any blockage.
How do I replace belt
remove the back plate (8 screws) at the rear of the machine being carefull of the sharp edge and replace belt simple operation
I need a user manual for AWZ410-1000
Start out by searching for the manufacturers web site and see if they offer down loadable/printable PDF files on the model you have...
If not; then they should have a list of local authorized dealers...
Some companies supply owners manuals for free, others might charge you for the info. good luck.
How do i get instructions for no longer stocked product
You can try going to this website but you will need to get the full model number to your machines. I tried with the number you posted and that is not enough of a number to make a match.http://www.searspartsdirect.com/
Hope this helps.
