20 Most Recent Kenmore 3.8 cu. ft. HE3 Front Load Washer Questions & Answers
indicates that the tub support rods have failed at the air dampners
the fix is new rods from the service agent spares and a re levelling if the tub ,not the machine
Kenmore 3.8 cu.... | Answered on Nov 20, 2017
If you take the top off, you can see the whole part called the dispenser, https://www.searspartsdirect.com/model-number/11042832200/0583/0153200.html
Check all the hoses etc. Yes you can even run the machine with the top off and see where the leak is. To take the top off there are three screws in the back at the top and when you remove those, the whole top lifts a slides back and comes off.
Kenmore 3.8 cu.... | Answered on Oct 14, 2017
Have you tried less items? It could be the load is not balanced. Try placing items around the tub evenly. This unit is about 12 yrs old so it could be a bearing.
Kenmore 3.8 cu.... | Answered on May 03, 2017
YOUR PROBLEM IS DOOR SWITCH OR CLOGED DRAIN PUMP THER SHOULD BE A ACCESS PANEL FOR THE DRAIN PUMP SO YOU CAN GET TO THE PUMP AND UNSCREW THE OUTLET TO UNCLOG DRAIN
Kenmore 3.8 cu.... | Answered on Apr 26, 2017
yes u have to now replace the blower fan housing u may be able to take apart and remove broken piece byt may not run properly or circulate heat and air as it suppose to
Kenmore 3.8 cu.... | Answered on Mar 24, 2017
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Kenmore 3.8 cu.... | Answered on Nov 16, 2016
F13 is
Dispenser Circuit Error
If the dispenser motor is not able to be driven to it's proper position.
Check mechanical linkage from dispenser motor to the top of the dispenser
Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
Check Dispenser Motor
i snagged this answer from another site
i think its a worn bit of plastic
as it becomes britten when not always wet
much like a boat out of water
Kenmore 3.8 cu.... | Answered on Feb 21, 2016
Shirley, you answered your own question.
Kenmore (((((3.8 cu. ft.))))) HE3 Front Load Washer
3.8 cu ft. drum
Not come across anything like it before, however, check your manual and see what it says about the position of the valve at the back of machine, if you've not already done so....otherwise goodluck.
Kenmore 3.8 cu.... | Answered on Mar 06, 2015
Check that the machine is not on an auto delayed start. Strange that it starts itself. If a solenoid fails, 2 things happen. They either don't let water in at all, or they don't stop letting water in. If its not on an auto delayed start, I suggest that it could be a faulty main control board . You can stop the machine by turning the water off and switching the machine off at the socket when not in use.
Kenmore 3.8 cu.... | Answered on Jan 03, 2015
You have a faulty fill valve. located where the fill hose is attached. if it is a hot & cold fill then turn tap off one at a time to check which valve is faulty. Replace faulty valve.
Kenmore 3.8 cu.... | Answered on Oct 04, 2014
Is the plastic housing (Outer Tub) in good shape? If the old boot was ripped, It might be the spider is also broken. Can you move the inner tub by hand and see if it lifts upward? If so you might have to get a new one. I had the spider bracket in the rear of the inner tub break in 4 pieces and too expensive to weld. So I bought a new top loader.
Kenmore 3.8 cu.... | Answered on Sep 13, 2014
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
628 questions posted
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Gordon Richard...
View Most Popular
  • Kenmore Washing Machines
Most Popular Question
installed new never used kenmore
  • Washing Machines
