Acer Altos G500 Server Logo
Posted on Dec 06, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Adsl modem not working
Dear sir
I am not getting the adsl pppoe led glows only the other leds are glowing thats why the internet is not getting link .hope you will be rescue me from this problem.
Jim Bruner
Level 2:
Scholar:
  • Expert 112 Answers
  • Posted on Dec 07, 2007
Jim Bruner
Expert
Level 2:
Scholar:
Answers
112
Questions
0
Helped
74373
Points
189
First you must have a steady led light on the on Power, Act and Lan, the Sync led will flash until the modem connects to the DSL line. If you are not running a router but only a modem, you will need to create a PPPOE network connection on the computer. If you are using a router with the DSL modem you will need to create the PPPOE connection only on the router. I had recently a problem with the DSL service to my home. My modem showed DSL connected but could not connect the PPPOE connection, the telephone company had to reset the circuit that I am on which fixed the problem. BPCS
My Alcatel linkzone WiFi modem model MW40CJ. Recently I tried updating the modem firmware but since then the modem has stopped working. I only see the FOUR led glowing constantly. PLZ HELP
Try a reset.
Turn the device on.
Hold down the Power and WPS keys simultaneously for 13 seconds.
Wait for all LED indicators to flash blue 4 times.
This indicates the device has been reset to factory mode.
I have resetted COMPEX WRL254G Wireless all in one ADSL MODEM/ROUTER..but when connecting the LED for the INTERNET option is not glowing and hence not able to connect to internet..kindly give me...
Call your internet provider, and ask for your User Id and password. Probably you will need extra help to setup your router, but Im confident your internet provider will help you.
Why can't I connect to the internet via my router but when I connect directly to the modem, I have internet access
If you don't reset the modem after connecting the router, the modem is still trying to send data to the MAC address of your PCs network card.
You need to disconnect power from everything, then power up the router first.
Once the LEDs on the router settle down, power up the modem.
Once the modem's LEDs have settled down, power up the computer.
You should now be able to access the internet through the router.
The only time this won't resolve the issue is if the PPPoE negotiation is being done by the PC and not programmed into the modem itself.
This is almost unheard of with modern DSL and ADSL modems today, but if that is the issue, you will need to contact your ISP for the information you will need to program the router to do the PPPoE login through the modem and reconfigure the computer to not do the PPPoE authentication any more.
I have the motorola sbv5120 surfboard with a coax bringing in a cable connection. i have to restart the modem EVERYTIME i want to use the internet because the ornage LINK light is constantly on and i cant...
led 2 to 9, gee it has 8 LED status lamps and not told you which one flashes nor what all do. sure #2 is on power sure.
the SBV is not a router at all so forgot to tell router
or is just 1 PC plugged into ethernet ports> yes/no? we can not see what you have or connected.
page 2 actual covers all that LED stuff in the manual RTM?
PDF#7
well kinks led is data up or down. any data moving up or down blicks this light so that is good blinking never bad.
not told at all , what PC is this.
nor OS
nor if PC using wifi or wired Etherenet. the later is best for testing
LED #5 ONLINE is what matters here first.
LED #5 must glow or call the IPS to get that working
if LED #5 does glow. use ethernet wired to SB
Led 7 and 8 is telephone VOIP so not important now.
not told wifi or ethenet fails, or both
not told if PC wired ethernet to top rear of SBV works
if at PC you ping 1.1.1.1 this works internet is good but DNS fails
if you ping same and it fails internet is dead but led #5 MUST GLOW.
The pc also shows connected in the task bard for SURE using ethernet
if all that passes, we then fix bad love/hate WIFI
ask how.
My modem is not working Power Led will be displed but not diplayed ADSL led, PPOE lead or LAN conection led. all are atteched with modem but
maybe there is no internet connection coming on your modem...ask your internet provider if your connection is disconnected..if its not..maybe your modem is not working properly..replacing it will help..
I hv a netgear wireless adsl modem and i m using bsnl broadband connection can send me the settings to configure the modem at my email id [email protected]
TYPE-I Modem Configuration - Huawei SmartAX MT880 Modem / SmartAx MT882 ADSL Modem Configuration
SmartAx MT880 ADSL Modem has One ethernet Port.
SmartAx MT882 ADSL Modem has One ethernet Port and one USB Port.
Set your computer IP address as 192.168.1.2
( If you are using USB port, install USB driver first)
Open Internet Explorer in the Address bar type the URL http://192.168.1.1
You will be propted for Username and Password.
Username: admin
Password: admin
Click on Home
Click on WAN setting
Your WAN Setting should be as follows:
PVC No.: PVC0
Wan type: PPP
Connection Type : PPPoE
VPI / VCI : 0/35
Default Route : Enabled
Username: yourusername@dataone
Password: yourpassword
Use DNS : Enabled
Click on Apply.
You will be asked to save and reboot.
Select Yes
Once your modem is rebooted , the summary page will be displayed .
The "Green" status of PVC0 status indicated that you are now connected. (in Summary page)
SmartAx MT882 ADSL Modem ADSL LED will turn 'Orange' from 'green' when succesfully connected
3helpful
2answers
Linksys router's internet led always red
if your not able to connect then id try rebooting it all start with the modem then the router and your pc see if that helps and if nothing works it very well could be the modem
2helpful
Adsl led is not glowing 802C D-link
when the adsl is not blinking that means your phone line is having problem plz ask your phone line provider to check the line.
61helpful
16answers
Nokia siemens ADSL Modem c2110 USB Driver
How can i download usb driver form ADSL Modem c2110 i want to down load the siemens c2110 usb modem driver.Please help me.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
