20 Most Recent Linksys WAG200G Router Questions & Answers
2answers
How to change mac address?
Every Ethernet card has a MAC address burned-in at the factory. At times, you may want to change this MAC address to one of your own choosing.
The procedures to change a MAC address are specific to each operating system.
How to change a MAC address in Microsoft Windows Under Windows, the MAC address is stored in a registry key. To change a MAC address, find that key with `regedit` and change it. Of course, Microsoft keeps moving the location of the key around!
Windows XP adds an option to change the MAC address on some network cards under the Advanced tab in the network adapter's Properties menu.
A much easier and more reliable method to change a MAC address under Windows is to use a software utility program designed to do this for you.
Macshift is a free utility that you can use to spoof your MAC address under Microsoft Windows.
How to change a MAC address in MacOS Instructions for changing the MAC address on a Macintosh can be found at MAC Spoofing on the Macintosh.
How to change a MAC address in FreeBSD In FreeBSD, you can change your MAC address with the `ifconfig <interface> link <address>` command.
How to change a MAC address in Linux Under Linux, you can change your MAC address with `ifconfig <interface> hw <class> <address>`, or you can use the GNU MAC Changer.
How to change a MAC address in Solaris In Solaris, you can change the MAC address with the `ifconfig <interface> <ether> <address>` command.
How to change a MAC address in OpenBSD OpenBSD does not, by default, allow you to change the MAC address. It is possible to change the MAC address under OpenBSD with sea.c.
How to change a MAC address in HP-UX Under HP-UX, you can change the MAC address in SAM by selecting Networking and Communications, then selecting the interface, then Action, Modify, Advanced Options. HP-UX refers to the MAC address as the "station address".
Changing a MAC Address in Hardware Speed Demon Adapters sells network cards which give you the ability to change the MAC address stored in their EERPROM.
This can give you the ability to change your MAC address under any operating system that supports either the PCI bus or PCMCIA Type II cards.
2/1/2018 1:49:28 PM • Linksys WAG200G... • Answered on Feb 01, 2018
4answers
Linksys WAG200G
OK the main problem right now that the only data carrier in Saudi Arabia (STC) is upgrading its infrastructure to provide high bandwidth to end users. STC is using Huawei MSAN which doesn't support linksys.
Here is a firmware update which they say it will overcome some of your problems.
Mirror1
Mirror2 - rapidshare.com
Mirror3 - Google Groups
here is the link for the original article in Arabic
8/26/2015 11:14:21 AM • Linksys WAG200G... • Answered on Aug 26, 2015
2answers
I need to assign public ip to my pc onlyhow to set
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAN settings and configure your router as static ip then enter ip address and dns server of internet service provider. then apply if you want ip from router enable DHCP Then click on wireless settings then turn on wifi set SSID . If you want secure wifi then in wireless security enable WEP enter WEP code it is your password for connect wi fi. Then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
10/24/2014 12:58:30 PM • Linksys WAG200G... • Answered on Oct 24, 2014
Password forgot
Press and hold the router reset button for 30 seconds after that access your router setting page and change the username and password. for more help http://www.wikihow.com/Reset-a-Linksys-Router-Password and how to use official services for router http://www.artipot.com/articles/1747713/convenient-official-resolutions-for-router-support.htm .
5/7/2014 5:08:46 AM • Linksys WAG200G... • Answered on May 07, 2014
2answers
Internet drops in and out. seems to connect again
If it is connected to a DSL modem then chances are that it is the modem dropping the connection every time a spike in line voltage occurs. Might want to try directly connecting to the modem and seeing if it still happens, if so then it is the ISP that you need to contact. If not then your router may be on the fritz.
Best of luck
4/12/2014 4:23:35 PM • Linksys WAG200G... • Answered on Apr 12, 2014
Driver download
You can download the Setup Wizard from this link, http://downloads.linksys.com/downloads/setupwizard/1224639158695/WAG200G_Setup_Wizard_v1.2.zip
2/24/2014 12:19:33 AM • Linksys WAG200G... • Answered on Feb 24, 2014
manual
How to configure linksys wag200g with ZyXel p-600
can some one help me please.. i am trying to reset my giffgaff password, but the link there are sending me wont let me click it?
8/11/2013 1:39:47 AM • Linksys WAG200G... • Answered on Aug 11, 2013
I have bought linksys wag200g **** its not working properly when i use wifi on my mobile
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
11/19/2012 9:13:57 AM • Linksys WAG200G... • Answered on Nov 19, 2012
0answers
0answers
Echolife HG532b AFAQ SHAMEL MODEL007
For port forwarding lists and steps check your device in this site and the steps as well.www.portforward.comthanks for choosing fixya.com and kindly rate this post.
1/4/2012 1:02:38 AM • Linksys WAG200G... • Answered on Jan 04, 2012
Linksys router WAG200G not automatically
try to access the Graphical Interface of your router.
1. Open your browser then type in on the address bar 192.168.1.1 then press Enter.
2. Type in the username and the password.
3. Check on the basic setup under basic setup there show be a dot on enable under Auto detect.
4. After putting a DOT click on save settings.
Hope this would help. Thanks.
5/30/2011 5:12:00 PM • Linksys WAG200G... • Answered on May 30, 2011
Linksys WAG200G Router  Logo
123 questions posted
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Linksys Computers & Internet
Most Popular Question
linksys wcg 200 hot spot put
  • Computers & Internet
