20 Most Recent
Acer Altos 600 Server Questions & Answers
Installation de win nt 4 sur acer altos 600
Si vous essayez d'installer Win NT, vous pourriez ne pas avoir de support; pas beaucoup de gens l'utilise et la nouvelle g?n?ration informatique pourrait m?me ne pas savoir comment vous aider ? l'installer, sp?cialement avec des "disquettes".
Altos server 600
The Acer Altos 600 does not offer any driver support for server 2003. I would suspect the error you a re running into will turn out to be a driver issue. If it were me, I would retire that old 600 and build yourself a desktop server if money is a concern. If money is not a concern, buy a nice Dell or HP server and be done with it.
Besides, the Altos is a Pentium 3 with 1.5 gig of RAM MAX. Is it not enough machine to run Server 03 properly.
BMC ERROR
Baseboard Management Controller -- Time to replace the server.
I need the user manual of Acer Altos 600 server. I
you either have to use a search engine with the words download (your product name and model) manual or you could visit the company's site, type your product name and model and opt for help and support
Is it possible to upgrade NT4.0 to Windows 2000 or XP?
Hi zhonglee upgrading from Win NT 4.0 to Win 2000 or XP on your server for personal use or single use is fine and definitely possible but mind you W2K Pro or XP will not provide services of Server OS like Win NT 4.0 Server
PXE-E61
1.) Verify that both the local and remote network interfaces are connected AND enabled/configured.
2.) Replace the cable.
If the system no longer reports a "Media test failure" error then the physical layer is good. Either your system will begin to PXE boot or you will need to verify that a PXE server is available/reachable in the same subnet/VLAN. (Barring any ACL issues, etc.)
Not much else to cover here. Considering this issue closed.
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
My Acer X1110 switches off as soon as blue light comes on?
it needs service, and service manuals are hard to find on anything by the likes of ACER.
this projector worked for 12 long years, did you own it 12 or bought a bad projector, no history told as I can buy dead projectors all day long. and hard nut problems even hacking done.
Acer X1110 data projector Standard throw projector..
did you know most projectors have serious grade protective devices inside??? (tamper and overheating are 2)
did you read owners manual page 32 yet, errors.
LED codes.?
there are 4 LED, and all 4 matter, projector turned (ON) (not one =1)
also in pairs glowing and also if blinking or not, so read page 32
it tells all that.
my guess is overheat failures, even cold, due fan slow or packed in lint after 12 years of use and no service done,.
https://manualzz.com/doc/49497108/acer-x1110-user-manual
some have dust filtler
a shop first cleans is out first, and check fan RPM with and LED tachometer.
this is all SOP.
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
