That is your linkage and it will tie in with your carburetor and throttle. Get the model number on your motor and do an online search for the make model and ask how to adjust your linkage. It should spit out everything you need. Make sure you're correct on your linkage settings because you can blow up a motor.
SOURCE: where is the battery located
The location of the battery depends on the particular model of the Dixie Chopper Silver Eagle line. All 50" and 60" Silver Eagle machines have the battery located under the seat. All 34" and 44" Silver Eagle machines have the battery located directly under the muffler and main frame between the support brackets in the battery case.
