Hello, stem
I was trying to help
you out here. Maybe this will help some? I was going back to some customers that asked questions
in the recent past and farther back, It appeared that no one answered some of them, So, I thought I
would take some of my personal time to see if I can help. Even though
this site may not have your exact model or brand, This link will help
you tons. Here is a link
to about everything you want to know about your oven, from repair
to trouble shooting it. Even pictures and video's. Just scroll around
and you
will see tons of information to almost any question you might have on
your Oven. If you go to this link and click around, I am sure you
will find out so much about your oven, you will know more than the
company that made it. The good thing about this link is, then you can
make the decision of DIY or hiring a pro. Here Is the link for you to
click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time
to rate my help and some kind words written would be appreciated for my
free help , I would appreciate it. Here is also my direct link to my own
pages of other areas of my expertise for other problems you might have
in Automotive,Appliance, and Electronics. Drop In anytime for my help.
Thanks,Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Thanks,Mike
http://beta.fixya.com/users/mc1bean
This is what I could find. Does this fit your oven? is this what you need to replace? I'm not really qualified on this unit, just tryin to find what I could for you Replacing the Cntrl-elec (Part Number: AP4089341) for Jenn-Air model JJW8527AAW: 1.) SHUT OFF POWER to the oven. 2.) Enter the model number at the find parts tab. 3.) View the diagram showing the Control Panel and associated parts. 4.) The control panel can be removed with a Phillips screw driver. There are 4 screws below and under the Control Panel. Remove all four. 5.) Now place your hands on both sides of the Control Panel and with CONTROLLED force lift up then out. I emphasize controlled force since above your Control Panel like mine may be a microwave oven. Wives are not cool when their appliances are chipped by oafish husbunds. 6.) Remove the three "ribbon" cables from the cntrl-elec from right to left. You may want to mark them so they are replaced properly. I needed my wife's hands for this while I held the Control Panel. Be careful not to bend the pins. I marked them with electrical tape. 7.) Use a flat bladed screw driver to pry up both ends of the 17 wire "ribbon" cable. Remove it by hand. 8.) Using a 1/4 inch hex rachet wrench to remove the four screws holding the cntrl-elec to Control Panel. 9.) Notice the old cntrl-elec's orientation. Now replace it with the new cntrl-elec with the same orientation. 10.) Fasten the cntrl-elec to the Control Panel with the hex screws. 11.) Carefully replace the 17 wire "ribbon" cable. 12.) Now carefully replace the three "ribbon" cables. 13.) INSURE all of the cables and wires are securely out of the way before replacing the Control Panel. I read on two posts where apparently this was not done and one or more of the cables and/or wires was damaged. This is not an easy fix. In fact for someone of my skill level this is "call the Jenn-Air repair technican time." 14.) Replace the Control Panel and fasten it in place with the screws from underneath. 15.) Turn on power to the oven and test all functions to insure a successful implementation of the cntrl-elec.
