F2 - E1
Keypad cable unplugged
1. Check keypad connector for firm connection (keypad connects to control board). 2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Kitchen aid is made by Whirlpool. There is a very good chance the then thermal fuse on the back of the oven has tripped. Whirlpools are very prone to this fuse tripping after a clean cycle. The noisy fan is just that a noisy fan it will probably need replacing. I have replace a couple of them over the years. When you pull the oven out to replace the thermal fuse replace the fan motor at the same tiome.
it will either be the sensor or the board,hopefully it's not the board,the part number for the sensor is 4455636 and subs to w10131825,the sensor is around 100 bucks,there should be a tech sheet on the machine most likely behind the touch pad on the top,it will tell you how to check the sensor with a meter,just unplug the sensor and read it out i think it's around 1100 ohms but check that on the tech sheet,if it's not the sensor most likely it will be the board part number 4453661 and that's around 300 buckseverything runs through this computer board but the sensor tells it how hot it is in the oven hopefully you have a bad sensor.let me know what you find,you'll most likely have to pull the oven to repair it but maybe just enough to get the top open,good luck
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused. You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display. This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Oven must be connected to the proper electrical
voltage and frequency as specified on the
model/serial rating plate. (The model/serial rating
plate is located on the oven door or on the oven
frame.)
Models rated from 7.3 to 9.6 kW at 240 volts
(5.5 to 7.2 kW at 208 volts) require a separate
40-ampere circuit. Models rated at 7.2 kW and
below at 240 volts (5.4 kW and below at 208
volts) require a separate 30-ampere circuit
Read off the power consumption of each oven and other equipment being fed from the cooker supply and have an electrician check the size of your cooker feed cable and main cooker breaker.
If the cable is not thick enough for the oven, you cannot increase the breaker size!
The breaker may of course be faulty, measure the current draw as the brealer trips.
