20 Most Recent
Miele H398BP2 / H398B2 Electric Double Oven Questions & Answers
When using the BAKE setting,
more than likely there is an issue with one of the temp sensors. you will need to press and hold clear then upper on off at the same time then release them then immed. press clear 3 times and hold on the 3rd till the service screen appears. on the right side you will see internal temp and catalyst temp they should be equal or very close. ill bet one of them is alot higher than the other if so the sensor will need replace but depends which one is bad as there are 2 of them. if the problem is on the lower just repeat above but use lower instead of upper
Cannot use self cleaning feature
Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problemheatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
How do i change the oven bulb
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
No heat
Since the control seems to be working properly, then it must either be a problem between the connection from the sensor to the oven control or possible bad sensor.
Check first to be sure your oven sensor has not shifted or moved from its position while baking by pushing or jiggling the plug.
If the sensor is connected properly then you might need to replace the sensor itself.
Take note: Disconnect the power to your electric oven before doing any oven maintenance.
I hope this helps!
Oven model# MLH4890B2SS, Lower oven would not heat
That could very well be a corroded connection between the sensor and the oven control. Or the sensor itself might be bad. Check it for continuity between either wire and frame.
Sense the oven control seems to be working it must be a problem with the sensor probe and sense the sensor is much cheaper than an oven control I would replace it. Note most new sensors come without the quick plug so you have to splice it in, so if the quick connect looks crappy to the one you have now then all you might have to do is simply bypass the connection.
If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Need to set time on Miele Oven H398B2?
Turn the upper oven on. Hit 'MORE' once or twice until you see 'SETTINGS' touch that and navigate to 'CLOCK' Once there, you can enter the time using the keypad. Hit 'OK' to exit. You can download the manual from the Miele website or request a printed version from them.
