Please advise what message LE stands for the E is flashing and dishwasher has stopped running. I think the model number is LD0550. Thanks Tanja
Hi Tanja
LE is motor error.
Empty water from inside the machine and try tripping the circuit breaker for a couple of minutes.
If that does no clear the error , then one of the following faults may have ocurred:
Wiring connection broken either bad connector on pump side or on timer control side, or faulty wiring harness.
The hose connected to impeller, or the impeller itself is blocked.
Motor or pump locked.
Faulty timer board.
