20 Most Recent LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Questions & Answers
If it were me I would use a small hole saw and run my braided stainless lines below the kick plate if code allows or at the back of the adjoining cabinet at a height which would not conflict with contents. You can buy an ABS dishwasher drain kit at Lowes or HD
LG 24 in. LDF... | Answered on Oct 26, 2017
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
LG 24 in. LDF... | Answered on Jul 08, 2016
If it's like my whirlpool, pull it out. Spring should be obvious. I doubt the hinge portion is broken. Spring may be. While it's out and springs tend to break, I would replace both. Several online appliance parts stores can help you with springs, my diagnostics and Hinge issue. They have been helpful to me.
LG 24 in. LDF... | Answered on Apr 02, 2015
there is a removeable filter at the bottom of the wash pan. It is usually a "screw-in" type of ring. See if this website can help..
www.applicancerepair.com -enter your make and model and search
LG 24 in. LDF... | Answered on Feb 12, 2015
https://www.youtube.com/watch?v=iABhGWZN778
LG 24 in. LDF... | Answered on Dec 23, 2014
Your dishwasher may have a filter located near the bottom or under the lower spray arm. This filter should be inspected and cleaned regularly. Follow your dishwasher owner's manual for specific instructions about how to properly remove and clean this filter, if equipped. If there are any holes or other damage to the filter, you'll need to replace it immediately to protect the dishwasher's pump and motor seals from damage.
LG 24 in. LDF... | Answered on Nov 28, 2014
Hi phtanner,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
LG 24 in. LDF... | Answered on Nov 14, 2014
MINE IS A LG 3850DD3006A AND YES THE GARBAGE DISPOSER GETS STRAWS AND JUNK IN IT. OR THE SCREEN ON THE TOP IS COVERED WITH MACARONI AND CHEESE. OR TWICE IN 4 YEARS THE MOTOR RING SPLIT AND THE MOTOR STARTED TO GRIND THAT RING TILL IT STOPPED ALLTOGETHER.
WHAT A PEACE OF JUNK!!
I ADMIT THE STRAWS ARE THE USERS FALT!
LG 24 in. LDF... | Answered on Jan 18, 2014
Check to see if there is a fuse near the electronics board.
LG 24 in. LDF... | Answered on Oct 18, 2013
LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Logo
176 questions posted
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
LG Dishwashers
  • LG Dishwashers
Most Popular Question
lg dishwasher leaking e1 error code
  • Dishwashers
