20 Most Recent LG LDF8812 Stainless Steel Built-in Dishwasher Questions & Answers
How to replace door springs
There is a service bulletin on the spring and connector(the cord that connects the spring to the door)The spring for the hinges part number is 4970ED4004G. You will need to change the connector assembly for each hinge (plastic colored black at each end of the cord instead of white) and that part number is 4933DD3001B. I use a heavy coat hanger with a hook bent at the end. At the other end where I hold it, I've bent the remaining length of the hanger into a handle of sorts. This gizmo is about 1.5 feet long. Release as much tension from the springs as possible by closing the door. Using a headlamp, remove the kick panel and locate where the springs are attached to the lower frame. Now, using the coat hanger, hook the end of the spring that is attached to the cord. Pull firmly against the spring tension with one hand and unhook the spring from the cord with the other. Do this on both sides. Reach underneath and remove the springs and replace them with the new versions, hooked in same place as the old ones. Replace the cords with the black upgraded versions and reverse the above procedure. You shouldn't have to remove the washer from the counter to do this. Just take your time and don't get frustrated--I do this all the time, you *don't*. The hardest part is trying to hold the spring forward enough to latch the cord connector onto the hinge. That's where having that coat hanger is a blessing! Otherwise, you're gonna have to pull the dishwasher out of the counter and that can be a real pill. Good luck and I hope I helped you!
9/13/2015 4:41:23 AM • LG LDF8812... • Answered on Sep 13, 2015
Lg dishwasher soap dispenser does not open during wash cycle
It is usually due to a lid spring problem or the solenoid operating the lid is faulty. In any case you need to replace the whole dispenser assembly. It looks like this (item K001) in this assembly chart. http://www.appliancepartspros.com/section-4-parts-for-lg-ldf8812st-asteeus.html To save hassles it might be worth switching to the dishwasher tablets instead of the powder. You simply drop the tablet in cutlery basket. A good brand like Finish should do you wonders. Might seem a bit expensive per wash but you extend the life of the dishwasher due to its cleaning efficiency.
4/23/2014 6:00:23 AM • LG LDF8812... • Answered on Apr 23, 2014
3answers
LG Dishwasher - drain hose replacement
Hello, I have just installed a similar model, and took the side panel off to see how it was put together ;)
The drain hose goes in the back of the dishwasher, then loops up the right side (as you are looking at the front)(this is to act as a "trap" to keep sewer gases from coming back into your washer, I assume), and then connects to the drain pump under the washer.
In order the change the hose, you will need to remove the left side panel, and the bottom panel, and this will give you access to the entire hose....
Hope this helps!
11/25/2013 1:48:11 PM • LG LDF8812... • Answered on Nov 25, 2013
Water not hot, dishes not clean or dry, and may not be draining entirely?
hay audra ,it seems like your heating element is bad , test it for continuity or open the door 2 minutes after you start the cycle (caution it may be hot ) good luck APPLIANCES R EN
3/15/2013 3:11:23 AM • LG LDF8812... • Answered on Mar 15, 2013
Lg Dishwater will not hold water
If it fills then drains then it will be a flood switch/water level sensor issue.
3/11/2012 10:40:49 PM • LG LDF8812... • Answered on Mar 11, 2012
Drain hose cracked and needs
you will have to pull the dishwasher out. and it is best to lay it on its back in order to get to it. there is also a clip in the bottom that holds it in place, all you need to do is pry it up and thats it all set.
9/4/2011 1:32:56 AM • LG LDF8812... • Answered on Sep 04, 2011
I am getting an LE
Refer this site where a likely solution is proposed. Hope it helps.
6/28/2011 3:38:49 AM • LG LDF8812... • Answered on Jun 28, 2011
Our stainless LG dishwasher does
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
3/23/2011 1:32:41 AM • LG LDF8812... • Answered on Mar 23, 2011
I am having problems getting dishwasher to restart
You should be able to reset it by tripping the breaker and waiting about 10 minutes. Then reset the breaker.
Best regards, --W/D--
1/30/2011 3:22:11 PM • LG LDF8812... • Answered on Jan 30, 2011
0answers
2answers
LG model LDS5811WW/02 has never cleaned the dishes
if the soap/detergent isn't completely rinsing out of dispenser, it sounds like water isn't directed the top spray-arm. possible a defective vario motor; as it directs water to the water channel that supplies water to the middle and upper spray arms.
8/23/2010 7:47:33 PM • LG LDF8812... • Answered on Aug 23, 2010
LE error what is stand for?
LE ERROR CODE ON FRONT LOAD WASHER IS A FAULT CODE FOR YOUR HALL SENSOR
8/22/2010 5:14:08 AM • LG LDF8812... • Answered on Aug 22, 2010
LG LDF8812 Stainless Steel Built-in Dishwasher Logo
62 questions posted
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
LG Dishwashers
  • LG Dishwashers
Most Popular Question
  • Dishwashers
